Traction Bars for 2012 Prerunner
Discussion in 'Suspension' started by BLK2012, Feb 22, 2013.
  1. Feb 22, 2013 at 6:12 PM
    BLK2012
    BLK2012 [OP] Active Member
    Joe
    AZ
    Looking for some trac bars to help with the axel wrap on my Tacoma. 6" lift and 35's are causing some vibes while accelerating from a stop. Any links would be appriciated.
  2. Mar 3, 2013 at 8:09 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
  3. Mar 3, 2013 at 8:11 AM
    jandrews
    '09 FourDubDee TRD OR
  4. Mar 3, 2013 at 8:12 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  5. Mar 3, 2013 at 8:13 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Just replace the leaf pack and sell your old one. Go with the allpro's or alcan's.
  6. Mar 3, 2013 at 8:16 AM
    PLC721
    Patrick
    Chandler, Az
    When i had my 6" lift, i replaced the block and add-a-leaf with the all-pro expos, made the ride 32x better than what it was!
  7. Mar 3, 2013 at 8:16 AM
    jandrews
    Those are an option, but:
    - I've never been impressed with Pro-Comp's "quality".
    - How do they mount? If it's a bolt on kit, again, color me unimpressed. If you need to do fab work, then you're back at the welder.
    Edit: Also, these motherfuckers destroy your clearance:
    New leaf packs do little to nothing to completely stop axle wrap without making the ride significantly harsher. They can diminish its severity though.
  8. Mar 3, 2013 at 8:23 AM
    Supertramp
    Supertramp dismember
    NC Mountains
    2009 Double Cab TRD Off-road.
    Looks like a solution looking for a problem.
  9. Mar 3, 2013 at 8:25 AM
    jandrews
    Axle wrap in these trucks is definitely a problem, especially off-road.
  10. Mar 3, 2013 at 9:13 AM
    BORNWILDGUY
    Rich
    Florida
    His axle wrap is caused buy running a 4" block. By replacing the leaf pack he will notice a major improvment and by going with the right one with not notice sigificant harshness. Knows from experience
  11. Mar 3, 2013 at 9:17 AM
    jandrews
    You could've just quoted me:
    It's pretty basic physics. Rotational torque of the axle housing can only be eliminated by bracing it with a rigid member opposing that torque.
    Leaf springs cannot be a rigid member and still flex to provide suspension travel. The stiffer the spring, and the closer the direct mount to the axle, the better it will control wrap. That said, complete elimination of wrap will not be garnered unless the rate is stiff enough to oppose wheel torque entirely (which leads to a terrible ride).
    Improvement? Yes. Elimination? No.
    Only true fix for wrap on these trucks is a traction bar. Whether or not the wrap is bad enough/worrisome enough that someone wants to go that route is their call. These trucks are designed from factory with the understanding some axle wrap will occur, and during on road use it really won't hurt anything as long as your leaf packs aren't completely dead.
  12. Mar 3, 2013 at 9:19 AM
    Supertramp
    NC Mountains
    Not a big enough problem for me to install something like that.
  13. Mar 3, 2013 at 9:22 AM
    jandrews
    You have a 1st gen. The concerns are a little different. FWIW I wouldn't install those pro-comp bars either. The design is terrible for offroad use.
    2gens produce enough power and with large enough tires and a heavy enough truck to break parts offroad from wrap. Blame Toyota for not upgrading the size of the drivetrain along with the rest of the truck and the increased engine power. And continuing to build trucks with piss-poor leaf springs, which doesn't help.
    Usage also varies. Some people beat on their trucks harder than others.
  14. Mar 3, 2013 at 9:33 AM
    jandrews
    6" kits are strange animals in the clearance category. The drop bracket gives them less running clearance than 3" lifts, but better approach/departure/breakover angles, assuming equal tire size.
    Those monstrosities hanging off his undercarriage eliminate his breakover improvements by filling in exactly the space created by the lift.
    Sure they'd help on road use. But if you're staying on road, you shoulda bought a car :stirthepot:
  15. Mar 3, 2013 at 9:41 AM
    Supra TT
    Eric
    Indiana
    That pro comp traction bar is :puke:
    I'd still stick with the ruffstuff one. You can make it so it follows the exact angle of your driveshaft so it doesn't get hung up. I've seen it on a 2nd gen I wheel with.
  16. Mar 3, 2013 at 9:49 AM
    jandrews
    Same.
  17. Mar 3, 2013 at 11:31 AM
    jandrews
    Eh? Normally red?
    That's RuffStuff's kit from SupraTT's reply fitted to a DCSB by Old Armortech Offroad.
  18. Mar 3, 2013 at 11:52 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  19. Mar 3, 2013 at 11:57 AM
    jandrews
    Is another option. I don't like it because it leverages on the studs that the 3rd member mounts to. I'd be worried it'd tweak 'em and result in a nasty diff leak at best, differential failure at worst.
    I'd run it before I ran the Pro Comp stuff though.
    I avoid settling for subpar work.
  20. Mar 3, 2013 at 11:58 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
