Traction Control question. 2010/w 3" lift and oversize tires.
Discussion in 'Technical Chat' started by ian408, Jan 24, 2010.
  1. Jan 24, 2010 at 10:19 PM
    ian408
    ian408 [OP] Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I have a 2010 that came with 3" lift and oversized tires.
    The biggest complaint I have is that driving on a moderately windy road, the traction control comes on rather randomly. Now if you're expecting it, it's not that bad. But, I would *think* that doing the speed limit or less and driving smoothly should *not* cause it to come on. But it does.
    As an example, I can take 10 similar right hand corners...on the 11th, TC comes on. If I repeat the experiment, the TC might come on in the 1st or any other. Or it might not.
    Tires are all correctly inflated. I don't know for sure about the alignment (but it tracks well).
    Anyone have an idea what the problem could be?
    P.S. I should add that road conditions are dry and "normal" ie; nothing that should cause it to come on.
  2. Jan 25, 2010 at 12:38 AM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    What size tires. My 09 has a 3in lift with 275/70/16 ang I have no problems with the TC coming on.
  3. Jan 25, 2010 at 6:07 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    285/70/17 is the tire size.
  4. Aug 10, 2010 at 3:07 PM
    wolfe0zero
    wolfe0zero opportunityisnowhere!
    David
    Irving, TX
    Black 09 Tacoma 4x4 TRD-Offroad shortbed
    Port installs: Borla exhaust Predator running boards Roof rack Bluetooth I-Pod interface Installed Toyota accessories: Bed mat J-hooks for bedrails Hood protector Aftermarket: Pioneer AVIC Z130BT Total Chaos UCAs Toytec ultimate lift kit Wet Okoles Arm rest mod Bed storage lock mod Stubby antenna Wade in channel deflectors Weathertech digital fit mats TYtoshi Grille Redline hood struts Waiting for install: Spidertraxx 1.25 spacers
    I have the same problem if I take u-turns too fast, or in my parking garage. And it's not a rub issue. I'm running 285/75/16
  5. Aug 11, 2010 at 6:10 PM
    Yota Newb
    Yota Newb Well-Known Member
    Bryan
    Indiana
    2010 5-Lug Regular Cab 2.7L 5 Speed
    Wierd. You guys are making me question my goal. I have a bone stock basic 2wd 2010 Taco regular cab and I was thinking about the ReadyLift 3" with maybe 31's... I would be interested in what is causing this too.
  6. Aug 12, 2010 at 8:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    I believe you need to have the speed sensors recalibrate at the stealership, something along those lines.
  7. Aug 12, 2010 at 9:24 AM
    98tacoma27
    Ben
    Not Beech Creek
  8. Aug 12, 2010 at 11:43 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
  9. Aug 12, 2010 at 12:15 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Weird, I haven't ever had a problem with mine. I'm running 285-70-17's.
  10. Aug 12, 2010 at 12:36 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    It's a pretty strange thing but i have to say, I'm surprised this even needs to be done. Seems like the system could be adaptive. Oh well.
    I'll post up when i do it/get it done and let you all know if it works. Be awesome if it does.
  11. Aug 12, 2010 at 12:51 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    That was where I was going. I mean think about it. Every once and a while, you get new tires. Some might be taller or wider or smaller. I don't about you, but I don't get mine from a dealer...why'd I want to go back to get the VSC reset every time I do that?
  12. Aug 14, 2010 at 9:18 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Had the VSC reset today. Jury is still out. I drove it on a road that should exacerbate the problem. I still experience the problem on some right turns but is definitely better than it was. Not perfect but better.
  13. Aug 14, 2010 at 9:28 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i'm running a 3" and 35s w/o this issue. seems to be very hit or miss on who it happens to and who it doesnt. i went from 32s to 33s to 35s and it has never become a problem and has only gone off in wet traction situations that i assume that it would.
