traction control question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chopperjones, Dec 12, 2011.
  1. Dec 13, 2011 at 10:45 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I've read the ABS mod, is it difficult? I have no knowledge of wiring and the such.
  2. Dec 13, 2011 at 10:48 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Nope, super easy man. I had no knowledge of wiring before those two mods. Your basicslly just grounding a wire and adding a toggle switch.
  3. Dec 13, 2011 at 11:08 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Cleaned up the thread. Now play nice.
  4. Dec 13, 2011 at 11:11 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Wow... 4 pages cut down to 2 just by removing the asshat comments. Well done MJP :laugh:
  5. Dec 13, 2011 at 11:12 AM
    mjp2
    NJ
    I used the big broom. :p
  6. Dec 13, 2011 at 11:22 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    THANK YOU VERY MUCH!!:)
  7. Dec 13, 2011 at 11:23 AM
    Pugga
    Massachusetts
    Now try to behave this time Mr. David K... :rolleyes:
  8. Dec 13, 2011 at 11:26 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I found the best way to play is to pop the hood and unplug the wheel sensor on the driver side frame rail. all abs, all traction control is dead... when you want it back just plug in the sensor, drive 100yrds and the system resets...
  9. Dec 13, 2011 at 11:35 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    You know what ill say to that.. :D. But ill say it again.. do it!! So easy and by far my favorite mods.
  10. Dec 13, 2011 at 11:41 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hahaha. Nice.. pick me up one of those will ya. I have a Few mods that are unfinished myself.
  11. Dec 13, 2011 at 11:46 AM
    forana
    Kaneohe, Hawaii
    ok so here's my questions on the ABS mod:
    1. when the switch is on it turns on the VSC off light. Does that mean VSC is off?
    2. Is TRAC still working?
    3. Does the locker actually engage?
    4. does this work on 2012s?
  12. Dec 13, 2011 at 11:47 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That's awesome . Haha
  13. Dec 13, 2011 at 11:49 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    When the with is turned on.. It turns off ABS and the light comes on
    No it isn't
    No it doesn't
    Not sure.. should tho. Don't see why it wouldnt.
  14. Dec 13, 2011 at 12:20 PM
    forana
    Kaneohe, Hawaii
    thanks for the info guys.
    OK so let's say I'm offroading in 4H. If I want to kill the ABS, then I can't have TRAC on too, correct? so if I kill ABS in 4H I am straight 4 wheel drive without any traction of any sort.
    In 4L atrac won't work either with the ABS kill switch on? But doesnt matter with the locker because it will kill it anyway...
  15. Dec 13, 2011 at 12:26 PM
    #35
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You can't turn off ABS without doing an ABS bypass mod
  16. Dec 13, 2011 at 12:29 PM
    #36
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Correct on the first one.
    Second one.. I'm not 100% but Im pretty sure it wont work.
    Here's what I do.. when i want to have fun.. and dont require 4wd, i turn the killswitch on which turns it all off.. (open diff).. or.. if I want more fun and traction.. I turn the killswitch off which turns it all on. i lock the rear in 2hi.. which turns it all off anyways..
    If I need 4wd, I turn the killswitch off.. then lock the rear and have locked 4wd (true 3wd drive).. then atrac if I need It.
  17. Dec 13, 2011 at 12:58 PM
    #37
    forana
    Kaneohe, Hawaii
    moose, when you say 2hi locker on, thats cause you did the locker mod?
    Sorry if I'm asking dumb questions, this traction stuff get confusing even after I read all the posts and material. I have ADD so I suck at organization in my head.
  18. Dec 13, 2011 at 1:06 PM
    #38
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    No worries man.. I was confused too.. especially after coming from an 06 without all this stuff. Lol. Yes, 2hi locked cuz I did the locker anytime mod.. which I highly suggest.. :D
  19. Dec 13, 2011 at 1:13 PM
    #39
    forana
    Kaneohe, Hawaii
    do you have the link of the mod that you did handy? I saw there were a few, but since yours worked I'd like to read that one.
  20. Dec 13, 2011 at 2:02 PM
    #40
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Ask and thou shall receive..
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/143882-locker-anytime-mod-help.html
    I used both that thread.. and the original mod thread that's linked in the first post. Between those two, you have all the info.
    Make sure to use the right relay from radioshack. I grabbed the wrong one and spent two days tryin to figure out what went wrong. Pm me if you need any help.
