Traction Control System bugging out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by davidryancummings, May 11, 2012.
  1. May 11, 2012 at 8:28 AM
    davidryancummings
    davidryancummings [OP] New Member
    Dave
    Grand Junction CO
    2010 double cab long bed TRD Sport
    3 in Spacer Lift with 33 in tires
    So my 2010 double cab long bed was bottoming out with light off roading so I put a 3 in spacer lift and some 285 BFGoodrich All Terrains on there. The truck now looks great and can off road like a champ. Problem is now my traction control system kicks in randomly on dry roads all the time, so annoying, anyone else have this issue?
  2. May 11, 2012 at 8:40 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The lift didn't do it, the tires did. A lift doesn't affect how the ABS system works but changing tire diameters will mess with the VSC. Either way, the fix is to have your skid control reset by a dealer.
    Also, if you're off roading and bottoming out, you might want to rethink that spacer lift.... Normally, when you bottom out, you hit the bump stops. Spacer lifts make it so the shock bottoms out before you hit the bump stops, forcing the shock to take the shock. The shock isn't meant to take this kind of force and will eventually snap, leaving you SOL (truck most likely will not be drivable when this happens).
  3. May 11, 2012 at 8:44 AM
    Pugga
    Massachusetts
    You're kidding me, the new trucks have a yaw sensor?!?! Damn, I'm glad I bought an older Taco before all that electronic crap got put in!!! :cool:
  4. May 11, 2012 at 8:51 AM
    davidryancummings
    Dave
    Grand Junction CO
    The off roading is very minor and I never bottom out anymore so I am psyched on the lift. Thanks for the info on getting the system reset by a dealer
  5. May 11, 2012 at 10:18 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Lift with VSC answer is the thread you want
  6. May 11, 2012 at 10:20 AM
    OZ-T
    Peter North
    British Columbia
  7. May 11, 2012 at 12:54 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
  8. May 11, 2012 at 12:58 PM
    Pugga
    Massachusetts
    Yeah, but my dumbed down 2007 says, WTF is ATRAC :notsure:
  9. May 11, 2012 at 1:16 PM
    BlueT
    NorthEast
    If you dont have it , Thats why you always get stuck. Maybe you dont know how to turn it on :D
