traction Control
Discussion in 'Technical Chat' started by mayhem538, Aug 12, 2011.
  1. Aug 12, 2011 at 12:57 PM
    mayhem538
    mayhem538 [OP] Member
    2010 TRD Taco
    2.5" fox coils
    How do I get rid of the traction control on a 2010 tocoma?
  2. Aug 12, 2011 at 12:59 PM
    mayhem538
    2010 TRD Taco
    2.5" fox coils
    Its annoying as hell when your trying to hall ass through the desert
  3. Aug 12, 2011 at 1:19 PM
    mayhem538
    2010 TRD Taco
    2.5" fox coils
    I'll try that thanks
  4. Aug 12, 2011 at 1:48 PM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    It wouldn't recommend locking the rear when you haul ass through the desert without seeing what it does to your handling first. It will significantly change your drift and tracking, just FYI.
  5. Aug 12, 2011 at 2:27 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    While the vehicle is stopped, hold in the VSC OFF switch for about 3-5 seconds (until indicator lights come on). This is in H2 or H4. In L4, there is no traction control unless you push the A-TRAC button (4WD Off Road Tacomas only).
    Of course, you can't race around the desert in low range, now can you... so no locker either.... Unless you are a 2WD Prerunner Off Road TRD.
    The traction control only works if you loose traction, so you are normally an open differential truck.
    You go spinning around in a nice 2010 Tacoma, well... the VSC will keep you from spinning out by correcting drift. Even with you manually shutting off the VSC, it is still lurking and will come back on if the truck senses you are about to roll over!
    Maybe, just silence the annoying beeper instead of shutting of the nifty system?
  6. Aug 12, 2011 at 3:55 PM
    David K
    You and the OP are not the only ones reading this... so when I pop in, it is to clarify or add something for the newbees or the old bees! You hadn't suggested to silence the beeper, which I think would be the first choice if it annoys anyone... afterall the technology that went into the VSC and TRAC systems, might as well get the most out of what you paid for, right?
  7. Aug 12, 2011 at 10:55 PM
    David K
    I agree if the beeping annoys you, turn off the beeping... but the system improves off road drivability with limited slip action front and rear. Have you not seen the rave reviews by the non Off Road Tacoma owners who have done the 4-Lo Trac Mod (yellow wire mod)? Trac works so well in H4, they figured out how to fool the system to give it to them in L4.
    If there was a true VSC OFF but the TRAC stayed on, then that would be a good compromise.
  8. Aug 12, 2011 at 11:03 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    VSC sucks when on loose ground and especially sucks in snow
  9. Aug 12, 2011 at 11:05 PM
    David K
    In the dirt maybe, but on a rain slick road where you take the corner too fast (in an empty bed pickup) the thing works at stopping the spin-out of the back end... Feels like it does when you use 4WD in the rain for better traction and control.
  10. Aug 12, 2011 at 11:07 PM
    OZ-T
    Peter North
    British Columbia
    Using 4wd in the rain is retarded
  11. Aug 12, 2011 at 11:10 PM
    David K
    ...and with TRAC and VSC nobody needs to use 4WD in the rain or A-TRAC (that is just a stupid statement that makes it look like you don't know what it is made for).
  12. Aug 12, 2011 at 11:20 PM
    OZ-T
    Peter North
    British Columbia
    If you're talking to me , using 4wd in the rain is retarded .
    I was editing my post when you quoted me originally , VSC sucks in loose grip conditions like gravel and especially snow .
    I didn't bring up Atrac
  13. Aug 12, 2011 at 11:22 PM
    David K
    I know you didn't Oz... my neighbor in So Cal and my Carolina friend were so quick to jump into the feeding frenzie, you must have missed their ATRAC humor posts?
    Did you see my Happy Birthday, hoser?:cool:
  14. Aug 12, 2011 at 11:24 PM
    OZ-T
    Peter North
    British Columbia
    Oh , I have them both on ignore
  15. Aug 12, 2011 at 11:25 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    to turn off traction control all you have to do is restart your truck and hold the traction control button for about 5 seconds. the little cars with skid marks and auto lsd light should come on then you have no traction control what so ever
  16. Aug 12, 2011 at 11:26 PM
    OZ-T
    Peter North
    British Columbia
    That limits it , but it's still in the background if you get really out of shape
  17. Aug 12, 2011 at 11:27 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    well im coming from experience with my truck it does not turn all the way off if i just stop even if i stop and put it in park it doesnt go completly off i have to shut my truck off then restart for it to work
  18. Aug 12, 2011 at 11:29 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    hahah special huh lmfao
  19. Aug 12, 2011 at 11:29 PM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    lol
    And your "Hauling ass" though the desert with a stock suspension?
  20. Aug 12, 2011 at 11:29 PM
    OZ-T
    Peter North
    British Columbia
    No need to restart
