Tradesman Truck Tops commercial style topper/shell
Discussion in 'Product Reviews' started by Toynado, Aug 4, 2017.
  1. Mar 1, 2019 at 8:25 AM
    #361
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    What is the thickest aluminum sheeting they offer?
    ARE now offers 0.64 on their ARE DCU.
  2. Mar 1, 2019 at 12:19 PM
    #362
    kylehorvath
    kylehorvath Well-Known Member
    Kyle
    Humboldt/Tuolumne/Stanislaus
    2007 Access Cab, 4x4
    Over GVWR and I keep adding more metal
    Yea, .035 for standard, 0.064 for DCU MAX.
    I believe Tradesman's entry skin is .040
  3. Mar 4, 2019 at 9:29 AM
    #363
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
  4. Mar 4, 2019 at 10:58 AM
    #364
    kylehorvath
    Kyle
  5. Mar 4, 2019 at 11:36 AM
    #365
    SportsmanJake
    VA
    2006 Tundra
    Thanks I forgot that zero.
    My ARE is .034 and it is extremely fragile. 0.040 is not thick enough either in my opinion.
    0.064 should be the thinnest anyone considers if they ever plan to take there truck offroad.
  6. Mar 4, 2019 at 12:39 PM
    #366
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    IMO it's more about the stiffness of the topper's frame than the skin thickness. If your topper's frame is flexing a bunch then it's going to load the skin which will ultimately fail. A well designed topper frame shouldn't be loading up the skin very much. Where you need skin thickness is to deal with impacts/contact with trail obstacles. To me, .063 sheet sounds like overkill for a skin and that they're making up for a bad frame design by adding on a thicker skin.
    All that said, time will tell how the Tradesmans (Tradesmen?) hold up. So far so good with mine so far.
    JusCampin and Toynado[OP] like this.
  7. Mar 4, 2019 at 12:55 PM
    #367
    SportsmanJake
    VA
    2006 Tundra
    I am not concerned with frame structure. My experience is from punctures and dents. Any east coast offroading requires contact with the bush. :D
    My 0.034 skinned ARE dents easily. I know 0.040 would do better, but if I am buying new and get to choose my options, I am going thickest possible.
  8. Mar 4, 2019 at 1:47 PM
    #368
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    Gotcha. I think I was mixing up conversations :D. I thought someone had mentioned an ARE shell tearing the skin.
    I've got a bunch of pin stripes on my topper from branches. No dents yet fortunately!
  9. Mar 4, 2019 at 7:17 PM
    #369
    kylehorvath
    Kyle
    I've had pretty thin skin on my Swiss topper, and yes, it dents easy (even from tools rattling around in the tool box side). I can walk on the roof, but it dents too. I'm curious to see how the ARE holds up. I had an ARE on my work truck and we beat the snot out of it, and its held up great, I'm guessing it was a DCU Max.
    So far, I think the difference between the DCU and DCU max is just the skin, frame is the same (according to ARE reps). And for another 1,000 dollars, I opted for the thinner stuff!
  10. Mar 5, 2019 at 12:23 PM
    #370
    Team-Taco
    Team-Taco Active Member
    Eric
    Tacoma DC LB
    Nil
    Does anybody have any side profile pics of a 2nd gen DCLB with a 26” tradesman/dcu? Just placed an order for my DCU (no tradesman in Michigan) and now I am questioning my 26” height choice :notsure:...
  11. Mar 5, 2019 at 3:30 PM
    #371
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
  12. Mar 5, 2019 at 8:32 PM
    #372
    kylehorvath
    Kyle
    What were/are your goals of the shell?
  13. Mar 5, 2019 at 10:28 PM
    #373
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Also check out the OP of this thread....he has lots of information and pictures regarding his build. IMO the 26" height looks good when you have a roof rack on the cab of the truck.
  14. Mar 6, 2019 at 5:32 AM
    #374
    Team-Taco
    Eric
    Tacoma DC LB
    Nil
    The goal is for a camping rig, I did barn doors and 26” height. I had seen a number of posters who had the 26” height but they all had a roof racks and gear on the cab of their trucks (which does add a bit of balance visually). With that being said I think the 26” height will suit my intended use better. Thanks for the advice on introspection of use!
  15. Mar 6, 2019 at 5:35 AM
    #375
    Team-Taco
    Eric
    Tacoma DC LB
    Nil
  16. Mar 6, 2019 at 11:51 AM
    #376
    kylehorvath
    Kyle
    I had a 23" (as seen in some of my pics), it was OK for camping, but very tight, and only good for sleep. We could barely get changed, had to sit sideways to drink, no headspace at all. I'm getting a 26" at cab, rising to 32", hoping that will be a perfect balance of aerodynamics, looks, and functionality.
    Sounds like a 26" shell should definitely suite your needs! Throw a Prinsu rack on your truck and it'll help deflect some air upwards, and give you more cargo space too :)
    Toynado[OP] likes this.
  17. Mar 6, 2019 at 11:52 AM
    #377
    kylehorvath
    Kyle
    Also, why barn doors?
    I see everyone opting for that, I could never get rid of my tailgate.
    AxisCab likes this.
  18. Mar 6, 2019 at 12:00 PM
    #378
    lfranchi
    lfranchi Member
    San Francisco, CA
    I had barn doors on my last truck, and I agree that I'm never leaving my tailgate again :)
    Super convenient for access, but not having a table to put things down (to cook, to pack, etc) was super annoying.
    ETAV8R likes this.
  19. Mar 6, 2019 at 1:49 PM
    #379
    Toynado
    Toynado [OP] Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    I could never get rid of my tailgate. I just got the Relentless Fab aluminum tailgate skin to make it flat so it’s easier to cook and set things on. I’m going to see how much to get it color matched quicksand Rhinolined
    kylehorvath[QUOTED] likes this.
  20. Mar 6, 2019 at 2:18 PM
    #380
    kylehorvath
    Kyle
    The argument I've heard for the barn doors was more room to fit objects inside... but i fail to see it that way, since once the tailgates down and the hatch is up, the area is actually MORE. hahaha.
