Trailer Brake controller?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nd4spdbh, Oct 28, 2015.
  1. Jan 31, 2019 at 6:32 AM
    #361
    bigwill837
    bigwill837 Well-Known Member
    Will
    Austin, TX
    1996 HZJ75 Land Cruiser Pickup
    Part number for the harness?
  2. Jan 31, 2019 at 7:25 AM
    #362
    bigwill837
    Will
    Austin, TX
    That's a super-clean install! Did you use the provided well-nut and screw to secure the Spetrum base plate to the cubby blank? Or the adhesive?
    Also, are you satisfied with the controller?
  3. Jan 31, 2019 at 8:24 AM
    #363
    bigwill837
    Will
    Austin, TX
    A few questions about this wiring diagram.
    I assume my 2019 TRD OR with tow package has this adapter harness under the dash, correct?
    If I'm wiring a Curt Spectrum controller, I just need to get the Tekonsha Toyota pigtail (3030-S)? Then I can splice the Spectrum controller wiring harness directly to the Tekonsha plug? Because Pin 8 already has the fused battery feed? Or do I need to add a separate 30 amp fuse from the battery to the controller?
    Edit: Never mind. Curt also offers a wiring harness for the Spectrum unit for complete plug and play connection (PN: C51455).
    Bob K likes this.
  4. Feb 18, 2019 at 12:53 PM
    #364
    TACO Outlaw
    TACO Outlaw Member
    '18 Magnetic Grey, Taco, TRD O.R.
    The picture I posted wasn't of my truck however it's installed in the last empty rocker switch panel, left of the steering wheel. I'm right handed so mine will be installed in one of the empty switch panels in the center. Like this one. I have yet to install one because I haven't purchased a larger trailer with electric brakes.
    philthytaco likes this.
  5. Feb 18, 2019 at 2:13 PM
    #365
    marc1
    marc1 Well-Known Member
    Marc
    West Coast Canada
    2017 Tacoma SR5
    Tonneau Pro Soft Fold
    I am a big Tekonsha fan, I have always used their controllers. In my '17 Tacoma I installed a P2 in the cubby (see picture). I used a 3017 harness but that has now been superseded with the 3031 (additional ground wire). I chose the P2 over the P3 for the smaller size and lower current requirement for the display.
    ra25mel likes this.
  6. Feb 18, 2019 at 2:23 PM
    #366
    RetiredRedneck
    RetiredRedneck Well-Known Member
    Bruce
    Port Moody, BC
    2018 TRD Off-Road - The Grey Ghost
    Toyota Roof Rails/Rack Toyota front Skid Plate BAKflip Hard Tonneau Cover iBoard Running Boards AVS Hood bug/rock deflector AVS Window Rain Gutters Amazon Centre Console Tray Larsen 2m/70cm antenna QYT VHF/UHF Mobile Radio Auxting LED Reverse Lights Taco Garage DMM with RAM bits-n-pieces Toyota OEM Bed Mat Interior LED Light upgrade - SuperBrightLEDS.com Pop-n-Lock OG Fabrication Centre Console Molle Panels Decals and badges removed CaliRaisedLED Amber Fogs, Ditch Lights and bumper Light Bar MESO Switch Panels AirOnBoard Switches Home Brew Auxiliary Electrics Panel
    Very cool, thank you much!
  7. Feb 18, 2019 at 2:35 PM
    #367
    bigwill837
    Will
    Austin, TX
    Here is my install of the Curt Spectrum controller. I wanted the brake controller to look stock in the interior. I thought this matched the best. I still have a little more work to do with the wiring and trimming the mount. The trim ring is about 1mm too large for the opening and doesn’t seat perfectly on the blank.
    C6-BF8-C3-B-CBBA-4755-9-BC0-506-E54-A491_61b60cc8f4138414b43fdad795f65185d1e7bf87.jpg
    Also, the plastic used for the blank isn’t as nice as the OEM stuff. But unless you’re looking, you can hardly tell the difference.
  8. Feb 18, 2019 at 2:55 PM
    #368
    RetiredRedneck
    Bruce
    Port Moody, BC
    Nice job...like with most DIY projects, you will be your own harshest critic...i think it looks good.
  9. Feb 18, 2019 at 3:01 PM
    #369
    bigwill837
    Will
    Austin, TX
    Thanks! I really want to test it out with one of these...
    0-BD7-D675-C7-E1-4-C8-A-BAFA-40-CC21240-_b7212cfffce0b90aad5e17cb871dee336d422ace.jpg
  10. Feb 18, 2019 at 6:41 PM
    #370
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    26282C12-A321-4B69-9877-37A34F065B52.jpg I followed your lead. I sanded the 1mm to fit flush and left room for a switch. I mounted to the left to see it better around the steering wheel.
    Oregon Fish, Bob K and RetiredRedneck like this.
  11. Mar 22, 2019 at 2:50 AM
    #371
    atebit
    atebit What's all this, then?
    The basement of the Alamo
    18 Inferno TRD OR 4x4 AC
    Just wondering why no love for the Tekonsha Primus? I only have one trailer with electric brakes so it seems like a good basic way to go?
  12. Mar 24, 2019 at 7:36 PM
    #372
    sabersoul1217
    sabersoul1217 Well-Known Member
    Jeremy
    Friendswood, TX
    2021 F-150
  13. Mar 24, 2019 at 9:18 PM
    #373
    Ziggyman
    Ziggyman Well-Known Member
    2018 TRD OR DBL 4x4
    That sure looks clean. I guess when my seven-year-old prodigy 2 dies I'll look to replace it with that...
  14. Apr 1, 2019 at 1:41 PM
    #374
    bigwill837
    Will
    Austin, TX
    Because I wanted the install to look as close to stock as possible.
    Boghog1 likes this.
  15. Jun 7, 2019 at 8:47 PM
    #375
    FoolishFrog
    FoolishFrog Member
    Mitch
    2018 Tacoma
    I did finally find the plug behind the kick panel (took two tries.) Waiting for the delivery of the Tekonsha P3 and the ESP mounting bracket for the cubby. I do know that somewhere on TW there are directions on how to remove the change cubby to the left of the steering wheel without removing the whole panel, because I’ve had it out and I know I didn’t pull the panel. Anybody know where to find that post? I tried searching every configuration of “change cubby” I could think of to no avail.
  16. Jun 7, 2019 at 10:18 PM
    #376
    xzatx
    xzatx Well-Known Member
    just got mine in
    i show in the video how to remove the cubby
    http://www.youtube.com/watch?v=Z5bmdBjQbZs&t=159s
  17. Jun 7, 2019 at 10:22 PM
    #377
    xzatx
    i got the 2019 trd OR with TOW PACKAGE
  18. Jun 8, 2019 at 6:11 AM
    #378
    FoolishFrog
    FoolishFrog Member
    Mitch
    2018 Tacoma
    “just got mine in
    i show in the video how to remove the cubby”
    Although I appreciate the video for how to remove the panel if it should come to that, I’m trying to remember how I got the cubby out before without pulling that panel and disconnecting all the switches..
  19. Jun 8, 2019 at 6:29 AM
    #379
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Do the 19s come with a factory trailer brake controller?
    My ford work truck has a factory controller as part of the tow package. It works well too.
  20. Jun 8, 2019 at 7:36 AM
    #380
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    I just purchased and installed a Tekonsha Primus IQ controller in my 2011. I chose the spot just below my left-side change pocket, although I'd have preferred where the pocket itself is. At any rate, it doesn't get in the way of my leg, I can see it when driving, and it's easy to reach while driving if I need to manually apply the trailer brake. It doesn't affect the hood release, but sits right next to it.
    I ordered the Tekonsha two connector harness for it as well. It was plug and play; took 15 minutes to decide where to put the controller and actually mount it, and another 10 minutes to fish out the factory harness connector and plug the thing in and hide the extra wiring. Taking the drop-down change pocket out made that job a snap. Hooked up the trailer and drove down the road a ways to set the basic power level for braking.DSC00632.jpg DSC00634.jpg
