Trailer Brake Harness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VangaSTL, Nov 30, 2015.
  1. Nov 30, 2015 at 2:15 PM
    VangaSTL
    VangaSTL [OP] Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Ok first off. Excuse my ignorance, I'm new to trucks and towing etc.
    I was over in the 2nd gen section and someone said that the harness for the Trailer brake module is located in the glove compartment. I looked inside my 2016 box and didn't see anything. Before anyone asks... Yes I have the V6 Tow package from factory. Does the 3rd gen have the wiring harness pre-installed and if so, where is it?
  2. Nov 30, 2015 at 2:33 PM
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
    This is what you will need to hook up your brake controller. The harness connection is located behind the drivers side kick panel. Two of the more popular brake controllers are the Primus IQ and the Prodigy P2, I believe they are both made by Tekonsha. The above listed wiring harness will work with either one. The below pic shows the connection behind the kick panel. You can thank Jeff for the photo.
    Adapter :
    https://www.tacomaworld.com/out/?url=http://www.truckspring.com/products/Brake-Control-Wiring-Adapter-Kit-2-Plug__3017-P.aspx
    Ka5biw and VangaSTL[OP] like this.
  3. Dec 1, 2015 at 6:29 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Is that the little cubby thing behind the Drivers seat?
  4. Dec 1, 2015 at 7:32 AM
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    Kick panel is down by your left foot, under the dash.
  5. Dec 1, 2015 at 7:37 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    It's that white plug? I thought that was the OBDII. Well that's convenient
  6. Dec 1, 2015 at 3:46 PM
    Ka5biw
    Ka5biw Member
    Paul
    Lost Almost, New Mexico, United States since 1912
    2016 White TRD Sport
    Mike G, thanks for the photo. It helped me to know where to poke around. My connector was tucked behind all of the other wire bundles. I finally felt part of the connector and went digging.
  7. Jan 5, 2016 at 9:45 PM
    laggz
    laggz Well-Known Member
    2016 Tacoma TRD Sport 4x4
    I just got the 3017-p and was looking at which ports the wires are connected to and compared to what the plugin on the truck looks like. It looks like the truck plugin and the harness plugin have wires in different ports, is that correct? Are these the ground wires that should just be going to a plastic port?
