Trailer Harness issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Southland guy, Apr 26, 2017.
  1. Apr 26, 2017 at 4:00 PM
    Southland guy
    Southland guy [OP] New Member
    2000 Tacoma Extended Cab SR5 4X4
    I have a 2000 SR5 4x4 with a factory installed 4 pin trailer harness. When I hook up the trailer harness to the truck harness everything works but the right turn signal. The trailer harness checked good, any ideas what could possible be the issue?
  2. Apr 26, 2017 at 4:06 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Check the ground. Then wiggle the connection. Then pull bulb on trailer to verify it's good.but like 90% of trailer light issues is ground.
  3. Apr 26, 2017 at 4:12 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    so you tested the plug at the back of the truck and all wires/connections tested good?
    ^ check the connections on the trailer wiring.
    lucky13don[QUOTED] likes this.
  4. Apr 26, 2017 at 7:50 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I had the same issue....I had to put a new tail light converter in. It is what is tapped into the tail light and connects to the 4 pin
  5. Apr 27, 2017 at 1:19 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Time to break out the Meter and do some trouble shooting
    So many things it might be .
    the bulb
    a corroded socket. Not allowing a good ground.
    corroded plug
    damage to wiring someplace.
  6. Apr 27, 2017 at 2:35 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Do you have a meter and a safety pin? Pierce the coating on the green wire before the plug on the truck. If that one is not showing voltage, then the above is the correct answer. The converter boxes are the weak link.
    Do these test, a digital multi meter is not your friend. Ghost voltage will mess with the meter. They are just too sensitive. I like the good old fashioned analog multimeters for this application.
  7. Apr 27, 2017 at 3:41 AM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    Might check the fuses that run off the converter box also. I have the whole set up on here for sale and didn't realize there were fuses on the lines. each one has it's own fuse.
