trailer lights
Discussion in 'Towing' started by mike, Jun 3, 2007.
  1. Jun 3, 2007 at 11:04 AM
    mike
    mike [OP] New Member
    Hello All,
    Where is the fuse for the trailer lamps? I've checked all fuses but, I'm not sure I have found the one for the trailer connection. 03'
  2. Jun 3, 2007 at 3:52 PM
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    I thought the trailer harness was tied into the tail/brake lights of the rear lights on the bed.
    Therefore it should be your normal tail light / brake fuses.
  3. Jun 16, 2007 at 10:01 AM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Hey Mike,
    First off, Do you have the OEM trailer package on you Taco? if the answare is yes, then look on the rear cab wall behind the seat. On my 03 Double cab there is a black box (converter) there are aprox. 4 fuses that are on the harness that lead up to converter.
    the only other spot they put this converter on the 03 Taco's is under the rear bench seat for the (Extra Cab)
    The regular cab and double cab should have it mounted on the rear cab wall, drivers side.
    good luck..
