Trailer Lights
Discussion in 'General Automotive' started by IndigoTaco, Oct 27, 2009.
  1. Oct 27, 2009 at 7:18 AM
    IndigoTaco
    IndigoTaco [OP] Well-Known Member
    07 Access Cab Sport 4x4
    One of the lights on my boat trailer is out, I swapped out the bulb but to no avail. What else can it be? Fuse is ok. Ground is fine. Could it be the connectors at the truck's plug?
  2. Oct 27, 2009 at 7:23 AM
    Taco's for All
    Taco's for All Well-Known Member
    Lake George, NY
    2019 Tacoma TRD Off Road Double Cab
    Nothing at the moment
    Do you have a test light? When in doubt, I break mine out. $5.00 investment and I've used it hundreds of time over the past few years.
  3. Oct 27, 2009 at 7:23 AM
    PPD934
    PPD934 Well-Known Member
    Western Kentucky
    06 silver double TRD
    Running bars, tinted window (, TSB mod ,885 coils, OME shocks up front, AAl and procomp 9000 out back, partially debadged/black out the others, weathertech floor mats, grillcraft grill, TRD skid plate
    i wouldnt; think it would just go out but there is a check plug indicator you can can get at auto zone i think that plugs into your trucks harness and will have several lights on it. if they all don;t like up you know your problem is your truck and not your trailer
  4. Oct 27, 2009 at 7:26 AM
    IndigoTaco
    Thanks guys, will head over today and pick one up!
  5. Oct 27, 2009 at 7:29 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I've had the same problem with my boat trailer. I had the bulb go out replaced the bulb and it didn't work. The other lights on the trailer worked so i didn't think it was any wire or anything with my truck. The socket had alot of corrosion on it. I took some sand paper and sanded the corrosion off of it. I had the grease that is for electrical connection and put that in the socket. Light now works. Good Luck
