Trailer/towing electrical issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tommyboyrn, Jul 27, 2019.
  1. Jul 27, 2019 at 8:28 PM
    Tommyboyrn
    Tommyboyrn [OP] New Member
    Tom
    2005 Tacoma access cab 4wd manual transmission
    This is my first post so thanks in advance for info and time
    No previous issues with boat trailer/utlity trailer lights before. Headed home from lake this evening and noticed my running lights were out....i do have brake lights and reverse lights on trailer did work.
    The plug has only 1 or 3 red lights illuminated. The plug has a T an L and R...the T is only one illuminated.
    I checked fuses under hood and under dash and all looked okay.
    I guess next is to see if power to plug?
    Anyone have any hints
    Tullie D likes this.
  2. Jul 27, 2019 at 8:53 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Make sure it’s not a truck problem. Check your power and ground at the pigtail harness on the truck. Could be a trailer problem
  3. Jul 27, 2019 at 9:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d get a test light.
    Or a good volt meter.
    Then run checks below.
    If the truck HAS tail lights and the trailer does NOT check the 30amp towing fuse.
    If the 30 amp fuse is GOOD, check the towing Tail Light Relay.
    It the Relay is good, check power at the connection on the Trailer light Connector.
    If power is to the pin on the trailer light connection then check trailer wiring.
    I’d personally start at the trailer light pin connection.
    If it has power, then you have a trailer wiring issue.
    If it does not have power, then it is a truck side issue.
    Visit link below for Tow Connector Diagram.
    https://www.tacomaworld.com/threads/7-pin-trailer-connector-wiring-diagram.455153/
  4. Jul 27, 2019 at 9:23 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Are you using a 4 to 7 pin adapter by chance? If so, mine does this from time to time too. If I twist the plug just slightly in the receptacle, they start working normally again.
    TnShooter likes this.
  5. Jul 28, 2019 at 2:51 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Same on 4 to 7 if that twist does not work I have to clean the pins on the truck receptacle and have also on both the adapter and 4 pin on the trailer (ground is exposed and corrodes).
  6. Jul 28, 2019 at 4:00 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Welcome to the forum. My experience has been that a very large portion of trailer lighting issues are ground related. I've seen some really strange looking things caused by a poor ground. I'd eliminate that potential FIRST.
  7. Jul 28, 2019 at 6:26 AM
    Tommyboyrn
    Tom
    So I'll have truck tail lights truck hazard lights truck turn signals are all working on my truck so it's between the truck and the plug I'm assuming. Brake lights on a trailer work running lights don't......
  8. Jul 28, 2019 at 12:42 PM
    08TRDOFFROAD
    Dan
    Are you using a 4 to 7 pin adapter???
  9. Jul 28, 2019 at 1:07 PM
    Tommyboyrn
    Tom
    Yes i have adapter from 7 round to 5 flat (i have reverse lights on trailer)
    So i think i found it....i had power to plg thru adapter to front of trailer...i had inlight marker lights that when blown interrupted circuit....i changed those and completed circuit.
    Lotta fuss when i should've started there anyway
    TnShooter and 08TRDOFFROAD like this.
  10. Jul 28, 2019 at 1:12 PM
    08TRDOFFROAD
    Dan
    Glad you got it figured out. Electrical problems are the worst!
