Trailer wire harness pigtail part number?
Discussion in 'Towing' started by silver80surfer, Feb 22, 2017.
  1. Feb 22, 2017 at 5:12 PM
    silver80surfer
    silver80surfer [OP] Active Member
    Bill
    Iowa
    08 manual 4x4
    I am in need of the wire harness pig tail that has the flat four prong plug. I've been to the local dealership and they are incompetent and can find it in their system. If anyone has the Toyota part number or anything aftermarket that would work the info would be much appreciated. Thanks.
  2. Feb 22, 2017 at 5:24 PM
    Hoangde
    Hoangde Well-Known Member
  3. Feb 23, 2017 at 10:08 AM
    silver80surfer
    Bill
    Iowa
    08 manual 4x4
    Ok thanks for the info. Hoping to get an original part, I may just have to get up under there and make sure it's not aftermarket.
  4. Feb 24, 2017 at 5:49 AM
    tgear.shead
    tgear.shead Well-Known Member
    That doesn't appear to be what he is asking for.
    Sounds to me that he is just asking for the last segment of the wire that goes from the plug at the drivers side rear of the frame over to the center of the trailer hitch, but that he already has the rest of the factory trailer wiring kit in place.
    @silver80surfer : DO NOT use one of those toy trailer converter boxes. They load the trailer circuit onto your tail lights, which increases the draw on those circuits dangerously close to their maximum tolerance. If they do go over and blow the fuses, then not only do you lose your trailer lights, you also lose your TRUCK lights.
  5. Feb 24, 2017 at 5:57 AM
    tgear.shead
  6. Feb 24, 2017 at 6:01 AM
    tgear.shead
  7. Jul 26, 2017 at 2:33 PM
    silver80surfer
    Bill
    Iowa
    08 manual 4x4
    Found out it was a blown fuse and a bad splice. All worked out, thanks for the info either way.
  8. Sep 11, 2017 at 11:21 AM
    JcDillon
    JcDillon Well-Known Member
    Somerville, Tn
    2012 access cab taco
    Bed Lights, Camper Shell w/ led light strip, HUWMS, K&n 63 series CAI, mbrp s5326al exhaust, ride rite dual control airbags.
    This is the plug and play kit I have if anyone needs this.
  9. Sep 26, 2017 at 6:37 PM
    celica91st
    celica91st New Member
    D
    2009 Taco V6 4x4
