Tranny fluid change Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by kinside, Aug 14, 2010.
  1. Aug 14, 2010 at 12:45 AM
    kinside
    kinside [OP] Member
    Hello world!
    I've tried searching but couldn't find anything useful. I'm trying to do a drain and fill on my 02 tacoma v6 auto transmission for the first time. I got under the car and saw the drain plug but couldn't find the fill plug. Can someone describe where it is? Thanks in advance!
    Cheers!!!
  2. Aug 14, 2010 at 1:07 AM
    r3sistance
    r3sistance Well-Known Member
    Socal
    '19 Black Tacoma TRD Pro, '86 ae86 GTS
    Although I have the 4cyl engine, I do believe its the same for the first gen v6's. You fill through the dipstick.
  3. Aug 14, 2010 at 10:31 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I believe It's Sticky at the top of the page...01-04 FSM
  4. Aug 14, 2010 at 10:46 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
  5. Aug 14, 2010 at 12:40 PM
    kinside
    kinside [OP] Member
  6. Aug 19, 2010 at 1:26 PM
    vapovick
    vapovick Active Member
    1999 Toyota Tacoma 4x4
    yup dipstick, (((on my 2.7 liter 4 cyl 3RZFE)))its kinda a pain to see how much you have in there, you check the dip with the engine running but the fluid appears to be splashed up, making a good reading a little hard to do..
    The Haynes manual tells you exactly how much you will need to do if you can eyeball the fluid containers and make a good estimate. (be sure all is drained, I don't think that is possible without a pump) Someone please correct me if I am incorrect on that.
    good luck!
  7. Aug 19, 2010 at 3:41 PM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Ditto to all. Fill in dipstick. Owner's manual AND Toyota told me I needed 2.1 Qts for a 'pan drain' Turns out I needed almost 4 Qts. Ive done this 2-3 times and shift performance has improved. Im using Toyota T-IV ATF. Get a extra drainplug crush washer while youre at the dealer to prevent leaks. They are cheap
  8. Aug 19, 2010 at 7:51 PM
    kinside
    kinside [OP] Member
    My dipstick calls for dextron III. Is your old fluid T-IV? I cant seem to find Dextron III anywhere. I tried going to the dealer but they dont have any individual bottles for sale only barrels for dealership use only. Is it okay to mix T-IV with the drain and fill?
    Cheers!
  9. Aug 20, 2010 at 7:40 AM
    Coolidge
    So Cal, Ca
    2003 Pre Runner
    Use whatever the dipstick says. Some are Dex III (4 cyl?), some are T-IV (6cyl?). I get my ATF fluid from Toyota dealer
  10. Aug 20, 2010 at 8:12 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    nnnnnnnnnnnnoooooooooooo dont use the Toyota T-IV unless your tranny calls for it!!!!!!!!!!!! That stuff will ruin your tranny!!!!!!
    I called toyota to verify. I just did mine a few times to get a good fluid change. They factory fill with valvoline. They recommended that if your dipstick says dex II or III get the valvoline dex/merc thats what they fill with at the dealer if you have them service your tranny. I even bought the fluid from the parts counter at the Toyota dealership. $3.99qt Pretty good price, It was actually more expensive at Autozone.
    mine took a hair over 4 quarts buy 5 and you will be fine. A month or so after you change your fluid go buy another 4qts and do another change and you will be good!
  11. Aug 21, 2010 at 9:24 PM
    kinside
    kinside [OP] Member
    Really? Sounds kind of wierd that toyota would use valvoline dex/merc. I was hesitant about buying it at a local auto parts store but now I'll go ahead and buy. Good information. Thanks.
  12. Aug 21, 2010 at 9:58 PM
    RideFast
    Jesse
    Tacoma
    I felt the same thats why I called Toyota! If you look at the back of the dex/merc you will see that it says that it will meet all of the requirements of dexIII
  13. Aug 23, 2010 at 9:20 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    keep it cool...attitude isn't needed or welcome here
    ty
