Tranny fluid question
Discussion in '4 Cylinder' started by cicada83, Mar 12, 2010.
  1. Mar 12, 2010 at 9:55 AM
    cicada83
    cicada83 [OP] Well-Known Member
    Midland, MI
    Retro white SR5 4x4
    Volant ram air, Bestop soft topper
    I like a lot of other Tacoma 5 speeders have a slight problem when shifting into 2nd gear from first. it will sometimes catch or skip off the syncros or "chunk". What I have noticed though is when the temp is above 50 degrees outside I rarely have a problem; also when the truck warms up the 2nd gear issue in cold weather is less reoccurring.
    With that said is there any tranny fluid that is good for shifting in colder temperatures? I have tried synthetic and not impressed (actually worse redline mt90). Or is there an option to put a tranny warmer/blanket on to keep temp above 50 in all weather conditions? Just curious if anyone had experience with this...thanks for you time!!
  2. Mar 12, 2010 at 11:28 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Try a different synthetic....
    Believe it or not, but synthetics are different and can react differently to different transmissions. I owned a Jeep Wrangler and almost everyone recommended Redline MT90 because for some reason, Mobile 1 did something to the brass in the tranny...??? Weird.... but I had MT90 in there for 7 years with great success.
    I'd try Mobile 1........
    If that doesn't help, perhaps the tranny is starting to wear. How many miles on it?
  3. Mar 12, 2010 at 11:35 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    ^ I haven't used it myself yet, but I hear the Redline MT90 is great in these transmissions. I plan on using it in the future.
  4. Mar 12, 2010 at 12:22 PM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    thanks guys for the headsup. the redline was fine when it was warm out but as soon as it got cold it was like stirring molasses. I also ran mobile 1 synthetic and same as redline. I went to the valvoline mineral and i have had the best results. the turck has 12,400 miles on it and has been doing it since day 1. But it has gotten better. I dunno maybe it s still breaking in but it seems like there should be a fluid or a warmer that would help smooth it out.
  5. Mar 12, 2010 at 2:07 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Mine does this too and from what I've read others have had the same complaint about the shifting. I think I've read that the dealers even said that the rough shifting was normal.
    The URD short shifter improves things, but there is a noticeable difference when the temperature is colder outside. I run AMSoil 75w-90 in mine. It also did it with whatever oil was in there before when I bought the truck used. I've heard good things about Redline MT-90, but haven't tried it. I just take it easy on it until the oil gets circulated. I've got a little over 90k and it hasn't broken down yet, hopefully it won't.
  6. Mar 12, 2010 at 6:42 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    I just put the URD short shifter in mine and I smile every time i shift...do it
  7. Mar 12, 2010 at 7:00 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    try redline
