tranny problems
Discussion in 'Technical Chat' started by Bud, Oct 30, 2006.
  1. Oct 30, 2006 at 9:14 AM
    Bud
    Bud [OP] Member
    I've been experiencing the same problems with the Tacoma 06 V6 5sp auto tranny shift up and down unnessarily when using the cruise control and then it suddenly increasing the set speed by 10 or more K on flat level highway. Scared the heck out of me. If I drive slowly at posted speeds without the cruise control engaged my best mileage is 20 mpg. but it's usually around 18to 19 mpg. From a dead stop at the lights with brakes engaged you are able to feel the truck wanting to jump or lurch forward. You really need to be aware that your foot is into that pedal when stopped. Also have the shuddering problem from quick acceleration and deceleration when using the transmission shifting from 5 to 4 while applying brakes. It almost feels like the rear end shuddering. We just had are first snowfall of the year and I've had an opportunity to drive in some crappy conditions just the last couple of days using the 4 wheel drive. With the current factory tires Bridgestone Dueler H/T 265/65R17. Terrible on snow and ice, Tacoma was having real problems with traction on the corners and even manueuvering through the parking lots. I would not trust those tires to get me out of a ditch. I've defiendly got to purchase some winter tires and put them on winter rims. (any suggestions would be helpful).
  2. Oct 30, 2006 at 11:12 AM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    i believe the 05+ auto transmissions are built to mimic a manual transmission. they up shift and downshift at points where the driver would shift if driving a 5/6 speed.
  3. Oct 30, 2006 at 11:16 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    You Sir are correct. I also recommend getting some decent winter tires on the rig. Mine came with the BFG All Terrian's and they work really well for an all around tire.
  4. Oct 24, 2013 at 4:19 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Dammit Tapatalk...
