Tranny Shifting Early
Discussion in '2nd Gen. Tacomas (2005-2015)' started by llibrm, Feb 9, 2013.
  1. Feb 9, 2013 at 12:25 PM
    llibrm
    llibrm [OP] OH NOOOOOO!
    Bill
    Convection Oven, Az
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s
    So the other day I was feeling a little froggy and started hot rodding a little. I noticed the transmission was shifting from 1st to 2nd very early (around 3-3500rpm), but 2nd to 3rd and so on would run out to redline. Is there something askew or is the normal?
  2. Feb 9, 2013 at 12:25 PM
    OZ-T
    OZ-T You chose ... wisely
    Peter North
    British Columbia
    In D ?
  3. Feb 9, 2013 at 12:31 PM
    llibrm
    Bill
    Convection Oven, Az
    Yes. I really only take it out I drive when wheeling
  4. Feb 9, 2013 at 12:45 PM
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    These trannies shift like mush in my opinion.. I would like to increase the line pressure and firm up the shifts for sure.. I am not sure if I it can be done easily..
    I am out of the Dodge world.. This Taco is my first non-Mopar truck..
  5. Feb 9, 2013 at 2:43 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Welcome to the world of transmissions that last longer than 80,000 miles.
  6. Feb 12, 2013 at 8:33 PM
    llibrm
    Bill
    Convection Oven, Az
    Any new thoughts?
    Bump
  7. Feb 12, 2013 at 8:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Mopar the manufacturer of the world worst transmissions IMO.
    OP I have no idea what is going on with your transmission. I drive normally because I am older. Maybe some of these young kids in here could help.
  8. Feb 12, 2013 at 10:21 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Floor it. that will solve your problems. Then you shift at 5k every time every gear.
  9. Feb 13, 2013 at 7:20 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Yes, you can just press the pedal harder and the truck will stay in first gear, however you will be going around smoking your tires everywhere whenever you need to pull out of your driveway or something.
    Whenever i need to get out of a driveway, pull out of a side street, etc in a hurry, I drop the shifter down into 1 and pull out of wherever, then once I'm out on the main road, I step on the pedal to go quickly and move the shifter into 2 or higher. Because you're hard on the pedal when you move the shifter out of 1, the truck holds first gear...This eliminates that aggravating shift into 2nd halfway through you're pulling out of the driveway and the following jolt as the truck drops back into first when you stomp on the gas pedal. This transmission would be perfect if it would just hold first for a second or two longer...such a shame you cant adjust it at all...
