Tranny Wont Shift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Love My Taco, Dec 10, 2014.
  1. Dec 10, 2014 at 8:13 PM
    Love My Taco
    Love My Taco [OP] Active Member
    Justin
    Ohio
    05 TRD Sport xtra cab
    K&N CAI, 110 outlet in cab mod, ARE Cap, Yakima Racks, Stainless Bull Bar, tailgate lock
    05 Tacoma 159k all of the sudden (after frame recall fix)
    If I shift auto transmission into out of park, the shifter moves, but the truck doesn't go into gear(in all gears) nor does it register the shift on gauge cluster indicator.
    I'm guessing theres a shift position sensor or something? Please help, Taco stranded.
  2. Dec 10, 2014 at 8:16 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Sounds like the linkage between the shifter and the tranny disconnected.
  3. Dec 11, 2014 at 5:51 AM
    Love My Taco
    Justin
    Ohio
    Pretty sure the dealership screwed something up during frame recall fix, doubt they'll own up to it. 160k, no problems until they got a hold of it.
  4. Dec 11, 2014 at 6:35 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Slap that hoe and tell her to move!
  5. Dec 11, 2014 at 6:36 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    How long ago did you have the frame replace? They will own up to it. Just have to tell them
  6. Dec 11, 2014 at 6:40 AM
    Love My Taco
    Justin
    Ohio
    About 3 weeks ago, I'll give them a call, but until then. That truck is stuck in park. In a buddies driveway. uggh
  7. Dec 12, 2014 at 4:52 AM
    gearcruncher
    Canadain bumper technician
    STICKY SHIFTER / SHIFTER IS HARD TO MOVE
    Most of us would disconnect the shifter cable from the transmission lever and then verify the cable is free by hopping in the truck and moving the shifter from park to low . We should feel nothing because the shifter cable is no longer connected to the transmission . If the shifter is still tight to move , we know that the issue resides in the cable or the plastic shifter cover . A quick lube job is going to fix that up .
    Next , with the shifter cable removed from the transmission lever , try and manually move that transmission lever by hand . You should feel click , click , click and it should be fairly easy to move with your hands . If you cant move it by hand , remove the PRNDL switch shown on page 16 at this link , it shows the switch in question . Spray the heck out of it . Some guys actually have to replace the PRNDL switch becuase of corrosion .The PRNDL switch gets very tight when it corrodes
    When the switch is removed , you can spray the seal on the transmission that sits behind the switch to see if there are additional problems with the lever shaft since the lever shaft is also known to corrode .
    , then take a small screwdriver and pry the lever seal away from the shifter selector shaft enough to blast some lubricant between the seal until you get the lever to move by hand .Might have to work it back and forth a little but its going to free up . You should have the wheels blocked when you do this .Both of these issues are very common
    http://www.toyotatundraforum.com/pdf/A750E.pdf
    Next , place the transmission gear shifter in park and " REMOVE THE KEY "
    Throw the key on the drivers seat until your done .
    Go to rear of truck and manually push it by hand to verify the truck is actually in park . Go back under the truck and check to see if the shifter cable lines up perfectly with the hole in the transmission lever . If it doesnt line up , adjust the shifter cable until it fits perfectly into the transmission lever . The adjustment is under the shift counsole .
    Once the cable is aligned with the transmission shift lever , verify the truck will only start in park and nuetral .
    Shifter stuck in park http://www.tacomaworld.com/forum/2nd...-failed-2.html
  8. Dec 12, 2014 at 5:32 AM
    Love My Taco
    Justin
    Ohio
    UPDATE:
    Thanks all for your input, turns out the shifter cable was "unclipped". This was a two person job to diagnose, once the tow truck guy got there, he crawled underneath, I shifted, then we could see the cable kind of hopping around, he grabbed it and pulled until, the indicator on the dash said we were in drive, drove it onto the flatbed, hauled it to the dealership, easy fix, nothing out of pocket.
    Gotta give some props to Kings Toyota, although they didn't admit it was on them (hard to tell), they fixed it.
