Trans fluid and diff fluid change 2wd prerunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by traviskx, Sep 16, 2019.
  1. Sep 16, 2019 at 8:38 AM
    traviskx
    traviskx [OP] Well-Known Member
    Travis
    Apple Valley , CA
    2008 Toyota Tacoma Pre-Runner 2WD 5SPD
    n/a
    Hey there guys. I was wondering if my 2wd prerunner has a LSD. I have read a few threads saying certain years and up have them. But im assuming because I dont have any locking controls, and its 2wd, that I dont.
    I dont have any history of service done on this vehicle.
    its 75w-90 for the trans fluid , what is the capacity for 5 speed? 2.4?
    and what is the weight for the diff?
  2. Sep 16, 2019 at 8:55 AM
    mojojojo78
    mojojojo78 Well-Known Member
    2007 Prerunner Access Cab SR5 V6 6 Speed Manual
    None... yet
    I might be wrong here, but I believe only the TRD Sport had a LSD. The TRD Off-Road had a locker. But the non TRD models had an open diff. And the TRD never came with the 4 Cylinder.
    If yours has one, it is probably aftermarket. You can see if it does by jacking up the rear and spinning the tires. Have a friend hold the opposite wheel and if it can spin in the opposite direction, its an open diff. If it doesn't then you have a LSD. You'll need your transmission in neutral.
  3. Sep 16, 2019 at 8:59 AM
    traviskx
    Travis
    Apple Valley , CA
    n/a
    Im just going to go off on a limb and say it doesn't truck is incredibly stock. doubt prev. owner would of done so.
  4. Sep 16, 2019 at 9:49 AM
    traviskx
    Travis
    Apple Valley , CA
    n/a
    Im going to get 5 qts total for the trans and diff of 75w90 full syn.
  5. Sep 18, 2019 at 10:18 PM
    traviskx
    Travis
    Apple Valley , CA
    n/a
    Changed them out. I had a hell of a time getting the trans fill bolt out. It came pre rounded by the previous owner! What a nice guy.. It also didnt crack open after marinating in penetrating fluid overnight, which sucked. I tried again, didnt work. Tried heating it with torch. no dice. Tried chiseling it out, Noope. Had to finally go and call a mobile welder to weld a nut to it.. Finally was able to break it loose. Jesus christ.. Pumped 2qts back into it, Which 2.2-2.5 came out. Idk which for sure, because oil pan I had to catch fluid had some liquid in it also. But anyways. Bought new fill plug, and crush washer, which also, previous owner neglected to put it back on. Which thankfully didnt make a difference prior. *no leaks* And the drain also didnt have one. I just figured if it was fine before, Id do the same with the drain. I put a bit of silicone on both of them just for good measure. No leaks. Runs fine.
    Also - used walmart full syn 75w-90 in both trans and diff. For u guys saying to buy expensive shit $20 a quart. Idk why. Drives fine. If not better then before.
