Trans mount
Discussion in '1st Gen. Tacomas (1995-2004)' started by toastyjosh, Nov 8, 2013.
  1. Nov 8, 2013 at 9:00 AM
    toastyjosh
    toastyjosh [OP] Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    I am going to replace my trans mount, I has some splits in the rubber and I am thinking that It is related to my drivetrain viberation at speed.
    So after looking at replacement mounts I found this
    http://www.armortechoffroad.com/Tacoma-Transmission-Mount_p_69.html
    [​IMG][​IMG][​IMG]
    • Precision Engineered to Eliminate Transmission Movement and Shifter Slap Problems
    • Made of Quality Energy Suspension Poly Round Bushings
    • Laser Cut and CNC Formed Thick Steel Plates for the Best Fit Possible
    • Direct Replacement of Stock Mount
    • Zinc plated ready to paint and bolt in
    • Direct Bolt-On for the R150F
    • 4WD Manual Transmission Found in 95-04 Tacoma with a 5VZ-FE (6 Cylinder) Engine
    In a continued effort to bring the highest quality parts to the Tacoma world 4x Innovations has created the first and only Super Duty transmission mount!Engineered from the ground up our SD mounts are the perfect solution to your transmission movement and shifter slap problems.This mount uses the same great Energy Suspension bushings as our mini truck mounts to serve you for a lifetime. These bushings will not split and fail on you, eliminating such worries associated with stock mounts.Your new mount comes with thicker steel plates that are laser cut and CNC formed for the best fit possible. Mounts come zinc plated and ready to install.
    TCC1326 transmission mount is a direct bolt in for the R150F 4wd manual transmission found in 95-04 Tacoma truck with a 5VZ-FE (6 cylinder) engine.
    I know that poly does not absorbe vibrations as well as rubber, but this thing looks like a great mount that will not break,
    What do you guys think??
    Taco33 likes this.
  2. Nov 8, 2013 at 9:15 AM
    toastyjosh
    northern New mexico
  3. Nov 8, 2013 at 9:30 AM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    How many mounts are on the 3.4L 5VZ-FE (6 cylinder) and how did you check them? Just curious.
  4. Nov 8, 2013 at 9:34 AM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    The rear mount (pictured) is at the rear of the transmission. It mounts on the crossmember right next to the transfer case.
    Gently pry up-down and side-to-side. It shouldnt move much. If it does, and you see lines (look carefully at the rubber blocks), you will want to replace it, since its on its way to being fully detached. Once its toast, theres really nothing holding down the rear end of your tranny and transfer case.
    Also OP, get your driveshaft rebalanced. when you replaced U-joints, the more than likely werent OEM, and they have the fill nipple outside on the cup. That weight is nominal, but its noticeable.
  5. Nov 8, 2013 at 11:20 AM
    toastyjosh
    northern New mexico
    Do i just take this to the driveshaft shop and ask them to rebalance?
    As far as the u joints I have checked them for play, and lubed them.
    I can not tell if there oem or after market units, I will double check when I get home.
  6. Nov 8, 2013 at 1:45 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If you do that..you HAVE to get solid motor mounts too.
    i have that mount and the BOMB proof motor mounts. motor mounts suck to get in..vibes at idle more..but not much. If anything i only noticed vibes when starting from a stop
  7. Aug 12, 2016 at 11:41 AM
    tan-ishman
    tan-ishman Well-Known Member
    San Diego,CA
    2005 DCSB
    a bunch of new/used parts....and some skids.
    not to revive this thread.... butttttt
    how did this trans mount turn out? any word?
  8. Aug 12, 2016 at 12:41 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    For what it is worth I have had my 4X Innovations mount in over 50,000 miles so far so good.
    I did notice more vibration when stopped but after this long I don`t notice it any more.
    The work is excellent at least on mine
  9. Aug 13, 2016 at 9:51 AM
    tan-ishman
    San Diego,CA
    2005 DCSB
    Thanks for the input. I am waiting for the rain to stop and my truck to dry before I go crawling underneath to look at that mount.
  10. Aug 15, 2016 at 7:20 AM
    tan-ishman
    San Diego,CA
    2005 DCSB
    How was your install @Wyoming09 ?
    I'm 80% sure the transmission mount is shredded on my truck and giving me an annoying clunk. Did it take you more than a few hours?
    "Brake" the bolts free --> support transmission--> remove old mount--> install new mount--> open beer
    did the install go like that?
  11. Aug 15, 2016 at 1:56 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Well it could have I installed mine when doing the clutch .
    Pretty straight forward then I always put new bolts in .
    Living in Pa sometimes it can be interesting getting hardware apart
    GQ7227 likes this.
  12. Aug 16, 2016 at 7:07 AM
    tan-ishman
    San Diego,CA
    2005 DCSB
    Well. I took a look under last night and everything is fine. Nothing is broke as far as I can see. Maybe the carrier bearing is getting worn, but no real idea of what's going on.
    Putting some new suspension on this week, but that's for the "what did you do today" thread.
    Thanks for your help guys
  13. Aug 16, 2016 at 12:31 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    For what it is worth I have been on some fresh paved roads so bad I pulled over and crawled under the truck thinking I was on the verge of a major failure.
    I got home Jacked all the wheels up looking for a broken belt on a tire .
    Never did Find anything !!
  14. Aug 17, 2016 at 10:40 AM
    tan-ishman
    San Diego,CA
    2005 DCSB
    I wish it was a road issue. I have been hunting but I think it honestly is just a whole hell of a lot of axle wrap. I'm going to ask in a different post for some help. I think I have a way to reduce it, but not sure quite yet.
    Thanks for the input man.
  15. Sep 16, 2020 at 9:21 AM
    tacomafanatic
    tacomafanatic Member
    Kyle
    Toronto, Ontario, Canada
    2004 tacoma xtracab v6 manual
    Does anyone know what the Toyota part number is for the mount? (2004 3.4v6 xtra cab 4x4 manual trans)
  16. Sep 16, 2020 at 10:13 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    2004 Ext Cab V6 5MT 4X4 162k
    881/5100/Dakars 4R wheels / TBU New frame
    Looks like 12371-07020 is the P/N
