Trans temp gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2.7taco, Jun 17, 2010.
  1. Jun 17, 2010 at 1:05 PM
    2.7taco
    2.7taco [OP] Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    I have no idea whats the reason it works when it wants to. Every now and then it will flicker on and then nothing. I am wondering if the sender has crapped out.
    The gauge has been wired from the battery with a relay and an in-line fuse. It also has a ground routed to the body ground near the battery. I have a routed all the wiring away from heat as much as possible and all of the connectors have been sealed from moisture as much as possible. All of the wires have been checked for continuity and all check out.
    I'm stumped.
  2. Jun 17, 2010 at 1:22 PM
    2.7taco
    Texas
    Its an autometer Z trans temp gauge. The sensor/sending unit is mounted in a block of aluminum and clamped to the line. The aluminum acts like heat sink, its off the actual ATF temp by only 5 degrees. The block is still clamped tight to the line.
  3. Jun 17, 2010 at 2:33 PM
    c0astie31
    c0astie31 TACO SUPREME
    Dennis
    Long Island ny
    2011 4Runner Trail Edition
    A LOT
    make sure that you put the circle connector in the right place on the temp probe, you need to have the grounf touching the bottom part of the sensor for it to work correctly.
  4. Jun 17, 2010 at 7:33 PM
    2.7taco
    Texas
    Explain more if you can a picture would help. As far as I have read the only ground is from the gauge to a good ground source according to Autometer.
  5. Jun 17, 2010 at 10:29 PM
    JKD
    JKD Well-Known Member
    Sending units often require a good local ground too.
  6. Jun 18, 2010 at 12:50 PM
    2.7taco
    Texas
    That must be it. Is there any way to set up a ground for the sender unit since I don't have a good area for a ground.
  7. Jun 18, 2010 at 2:47 PM
    JKD
    If the sending unit is metal and is clamped in an aluminum block, then ground the aluminum block. It doesn't have to be a big ground wire--small automotive wire will do just fine.
  8. Jun 18, 2010 at 6:26 PM
    2.7taco
    Texas
    Well searching around a little has served me good thanks for all the help. I will be adding a ground wire to my setup asap.
  9. Jun 19, 2010 at 4:29 PM
    2.7taco
    Texas
    Set the ground wire up and ran an easy test drive down the road the temp. averaged 180*F. I had it peak at 195*F for a little when I passed someone on the road. It may be time for a cooler.
