Trans temp sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by windsor, Oct 22, 2016.
  1. Jan 5, 2018 at 9:22 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    What gauge pillar pod did you use? Got a link?
  2. Jan 5, 2018 at 1:34 PM
    windsor
    windsor [OP] Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
  3. Jan 5, 2018 at 2:45 PM
    1slik55
    1slik55 Member
    That's nice work, I miss the pillar guage setup from my Excursion. I wish the Tacoma had a test port or something else available to make this easier, although, your work looks outstanding.
  4. Apr 26, 2018 at 10:10 PM
    windsor
    Homeless in Oregon
    Update. Hauled home a 7x16 enclosed trailer today. Driving through Portland OR in traffic at 5pm, outside temp of 85. Trans temp got up to 180*. Once I was able to get it out on the highway, it stayed around 165* in 4th through the hills. About 150* in D on the flats.
    DaveB.inVa likes this.
  5. Oct 3, 2018 at 3:09 PM
    bigbear1612
    bigbear1612 Well-Known Member
    Gary
    2018 Toyota Tacoma TRD 4X4 silver sky metallic
    Ride Rite airbags with onboard compressor, Trail Ridge towing mirrors, 28,000 gwv external transmission cooler, Roll n Lock bed cover.
    Why not just install the temp sensor in the trans fluid out line?
  6. Oct 3, 2018 at 5:03 PM
    windsor
    Homeless in Oregon
    Because it was cleaner and easier to put it in the pan than to cut a line and add a fitting. Plus, it gave me the chance to check for and clean the gunk out of the pan. It still works well. I have verified temps with my Ethos a couple times.
  7. Sep 15, 2024 at 4:52 PM
    Tmar04
    Tmar04 Well-Known Member
    Terry
    2004 Tacoma prerunner
    What kinda gauge and sensor did you use? I have 2000 taco and want to do same thing you did. A link would be nice. Thanks a lot
  8. Sep 15, 2024 at 9:14 PM
    windsor
    Homeless in Oregon
    I don't have that truck anymore, so I'm not 100% but I think this is the one I used. https://www.autometer.com/2-trans-t...EeCE1YLhVzdgcXsoYuMaAhWtEALw_wcB&gclsrc=aw.ds
    I have had good luck with Autometer gauges. If you use a pod, you'll need 2 1/16 gauges. Here is the link to the 96-00 tacoma pod. https://gaugepods.com/products/4-runner-tacoma-2-pod-full-pillar
    I got the sensor bung on ebay I think. Autometer does sell them, but ebay or Amazon will be cheaper with no difference in quality, just look for one that doesn't look like it was meant for a toy. It needs a 1/8" npt bung. If you don't want it soldered/welded, companies like Moroso make bulkhead fittings with o-ring seals, but I would recommend silver soldered/welded bung.
  9. Sep 24, 2024 at 9:30 PM
    TyBud850
    TyBud850 Well-Known Member
    Tyler
    Defuniak Springs, Florida (NWFL)
    2012 Black Tacoma DC TRD-OR
    3” lift Icon 2.5 shocks king 650 coils, ALCAN LP W/Sumo springs & FOX 2.0, CBI MOAB 2.0 Front Bumper w/Smittybilt X20 10K winch, CBI Rock Sliders, Mobtown Reinforced Steel Skids & Bed Bars, CBI rear bumper,
    Thank you for the writeup! Definitely would like to keep an eye on the trans temps in the future. I wish there was a way the Scangauge could read trans temps but I haven't seen anything yet.
  10. Sep 24, 2024 at 9:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    ScanGauge can indeed read trans temps on 2nd gen automatics.
  11. Sep 24, 2024 at 9:52 PM
    windsor
    Homeless in Oregon
    As @Dm93 said, 2nd gen should be compatible for SG trans temp. I didn't go that route because I didn't really care for the look of the SG and I needed a place to put my air pressure gauge too.
