Trans. trouble
Discussion in '2nd Gen. Tacomas (2005-2015)' started by telejojo, Jul 3, 2014.
  1. Jul 3, 2014 at 7:36 PM
    telejojo
    telejojo [OP] Active Member
    Skip
    Huntsville AL.
    2014 Tacoma
    I have a 2014 Tacoma and I have noticed the transmission seems to be slipping for a second.I turned into a parking lot and got back on the gas and was like in neutral for a second and then bam in gear.It has felt like I got bumped from behind a few times I stopped at a light.It don't happen all the time but it is happening more often.I've only had it 3 weeks so I guess it's back to dealer.I should have kept my FJ.this is the second one the first one was totaled after 3 weeks and I replaced it with this one.Seems like Tacoma's are bad luck for me.
  2. Jul 3, 2014 at 7:40 PM
    shrekmoose
    shrekmoose Active Member
    Caleb
    Middle TN
    2016 TRDORDC
    Window tint. LED lighting
    These trucks seem to downshift pretty quick when u get off the gas. I thought my 13 was slipping but if it was slipping it would do it when you hammer on it.
  3. Jul 3, 2014 at 9:38 PM
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    mine is an 05, but the bump from behind feeling is normal for these trucks. Mine does it and if you search the internet you'll see others do to. As for the possible slipping, they're had been talk on here about trucks being low on transmission fluid straight from the factory. Might want to get that checked.I know that if I'm coasting slowly down a hill, make a turn and just barely give it had, the engine will rev and it seems to delay shifting to the proper gear. Doesn't do it if I give it more gas around turn. Similar to your issue?
  4. Jul 3, 2014 at 9:47 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    It is most likely low trans fluid. Had the same happen to me going around tight corners and thought it was traction control, but no lights or beeping. I ended up checking the trans fluid, and sure enough, it was low. When I filled it, I tried to simulate the situation, and it didn't do it again. Also, get that crap WS fluid out of your trans the first chance you get, plenty of other high quality fluids that far supersede WS out there.
  5. Jul 4, 2014 at 4:08 AM
    telejojo
    Skip
    Huntsville AL.
    2014 Tacoma
    Yes I've let off gas and got back on quick and there was a delay.
  6. Jul 4, 2014 at 4:33 AM
    gearcruncher
    Canadain bumper technician
  7. Jul 4, 2014 at 5:23 AM
    telejojo
    Skip
    Huntsville AL.
    2014 Tacoma
    My guess is that's what it is................Will take it in Monday.
  8. Jul 5, 2014 at 8:16 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    I have to ask when you hit the gas did you hear the engine rev higher or was there just a delay in the truck reacting. If the engine revs higher then the transmission slipped. If there was just a delay in the truck reacting it might have been throttle lag. People who have manual trans complain about throttle lag when they shift the engine revs like they still have their foot on the gas even though they don't. It is not as noticable on the autos but every now and then when I hit the gas there is a half second delay in the truck reacting. Either way I guess your best bet is to go back to the dealer and have it checked for peace of mind.
  9. Jul 7, 2014 at 8:26 AM
    telejojo
    Skip
    Huntsville AL.
    2014 Tacoma
    I stopped at a red light and as soon as the truck came to a stop it felt like I was bumped from behind,a downshift surge or something.
  10. Jul 7, 2014 at 8:31 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    did you have your AC on... if so that was probably the AC kicking on and the idle going up because of it.
  11. Oct 10, 2014 at 5:05 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    What ATF are you running? Amsoil atl?
  12. Oct 10, 2014 at 5:43 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The bumping at red lights is normal. Mine also slips every now and again. Seems worse in cold weather.
  13. Oct 10, 2014 at 5:46 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    This has been a problem with Tacoma's since 2005. Some say its axle wrap, some think its the transmission having issues. What I think the actual problem is, the driveshaft is binding when you come to a stop due to not having the inner splines greased up where the shafts come together. Our driveshafts aren't one solid piece, but several linked together. I had this issue on my 2005 dclb. It felt like someone bumped me from behind every time I came to a stop. I pulled apart the driveshaft, greased the splines, put back together and hardly noticed it anymore. If you have a block rear lift it may be axle wrap. Anyway, hope this helps.
  14. Oct 10, 2014 at 5:50 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I took my driveshaft down and greased the slip yolk and that got rid of the thud at stops/takeoffs for about 10,000 miles, but it's back again. I'm thinking about drilling and tapping it for a zerk. My transmission always shifted kinda soft until I flushed it via the cooler line method, now it has a definitive shift throughout all the gears. I believe that it may have been low on fluid from the factory. (I also added a spin on remote in-line transmission filter)
  15. Oct 10, 2014 at 5:54 PM
    reece13
    North Carolina
    Good idea on the remote trans filter. I don't know why car manufacturers steered away from this. Luckily I don't have to deal with it anymore (automatic) since I have a 6spd now.
  16. Oct 10, 2014 at 5:55 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    You beat me to it, mine does not usually bump at a stop, but almost always on takeoff. I have a theory that because my truck has quite a bit of axle wrap (leaf packs are getting worn out) it is bottoming out the slip yolk on the female side, causing the bump on takeoff.
