Transfer actuator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mizike77, Nov 29, 2014.
  1. Nov 4, 2016 at 11:28 AM
    #41
    Gasturbine
    Gasturbine Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    So pushing the shift rod all the way in (towards the front of the truck) is 2wd?
  2. Feb 20, 2020 at 9:30 PM
    #42
    Wicked Yoda
    Wicked Yoda New Member
    I found someone with a great explanation of the orientation for the pinion gear. Couldn’t find anything like this on the internet so I thought I’d share. Here’s how it goes:
    Only 2 of the rings should make contact with the pinion gear when set to 2wd, 4HI, 4Lo. The only time it makes contacts with all 3 is while it is indexing through the settings. The red markings are demonstrating the resting places for the pinion.
    BlownTaco, deanosaurus and 02Duck like this.
  3. Dec 23, 2020 at 7:40 AM
    #43
    burch86
    burch86 New Member
    2008 Tacoma 4 door
    I have an 08 Tacoma Sport. It would not go int 4WD the other day. Reading thru alot of these forums I removed the Front actuator, soldered the connections. No joy. Tapped on the transfer case actuator and it went into 4wd. Then I could not get it back into 2wd. I thought maybe it was out of sync with the 2wd/4wd switch and transfer case actuator. I removed the cover of the front actuator moved it into 2wd. Now the dash light flashed 4 the 4wd light. I verified the truck is in 2wd. 2wd/4wd switch is in 2wd. still will not go into 4wd when switched. I have tried to go to the troubleshooting link provided on these forums but they have been removed. Anyone have a good link? and alos a good part number for the sensors on the transfer case?
  4. Dec 23, 2020 at 11:03 AM
    #44
    gearcruncher
    Canadain bumper technician
    6 gearT444E likes this.
  5. Feb 11, 2021 at 10:34 AM
    #45
    BlownTaco
    BlownTaco New Member
    Indiana
    2009 Tacoma TRD Off-Road
    TRD Supercharger
    Sorry to bring up an old topic. Just for clarification, which of the labels in the picture are correct? The 2wd starting on the upper right side of the three straight contact pads, or on the left of them? Lol, I've been pulling my hair out with this truck.
  6. Feb 11, 2021 at 10:54 AM
    #46
    brickflair
    brickflair Well-Known Member
    Cerritos, CA
    '08 White TRD Offroad MT
    WeatherTech Mats +55hp
    To the left of them, i was confused as well.
    Recently took mine apart, cleaned the contacts, and put it back together. Everything worked!
  7. Feb 11, 2021 at 11:17 AM
    #47
    dbbd1
    dbbd1 Well-Known Member
    So, the hand written markings are correct?
  8. Feb 11, 2021 at 12:36 PM
    #48
    brickflair
    Cerritos, CA
    Yup
  9. Jul 26, 2022 at 5:46 PM
    #49
    Chrismacc
    Chrismacc New Member
    2010 4WD Tacoma
    Hi there, I’m in no way a mechanic but like to play around a little. Had a problem with the 4Lo engaging, so took it to my trustworthy mechanic and told me the the transfer actuator is done for…looking around I can only find (f.e. In rockauto) actuators (no idea if its a diff or a transfer actuator) so my question, since the picture looks just the same as some posted here, are they the same or one part wont replace the other?
    I found a couple, trying to keep Aisin, pictures uploaded.
    Thanks for absolutely any help on the matter, have been searching for days and am really lost93C3A388-B53A-4F11-8BF2-F7DF641E7B3A.jpgB8D444DF-F8B2-4239-8E41-7173FE06F3C1.jpg
  10. Jul 26, 2022 at 5:55 PM
    #50
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I could be wrong here, but it looks like the top one is for transfer case, and bottom one is for front diff
  11. Aug 1, 2022 at 10:05 AM
    #51
    Chrismacc
    2010 4WD Tacoma
    Thank you very much!!!! Will try the one you said, hope it will work
  12. Aug 1, 2022 at 10:22 AM
    #52
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Dm93 likes this.
  13. Aug 1, 2022 at 10:22 AM
    #53
    TnShooter
    Deogee
    STOCK
    @Chrismacc see my post above. Don’t order the top one.
    Dm93 likes this.
  14. Jul 16, 2023 at 3:46 PM
    #54
    VIBob
    VIBob New Member
    2007 TRD SPT 4DR
    3" Rough Country
    Hi everybody. I’ve gotten a lot of help from this group and this is my first post.
    I have a similar problem to what’s being discussed. As I removed the cover from my TCase actuator it rotated clockwise a bit which surprised me. It seemed to have some tension on it forcing it to rotate. I saw a YouTube video by Johnnie Jones where he showed that the 3 prongs on the pinion gear should be at the 3:00 position for 2H. Mine are at the 4:00 position, and by looking at Wicked Yoda’s photo above I think it’s in the transition zone which will confuse the ECU.
    If this is right, my question is how do I reposition it correctly?
    Thanks for any help.
  15. Jul 16, 2023 at 5:39 PM
    #55
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If the timing hasn't been messed with just rotate the gear as far counterclockwise as it will go, that should be 2wd.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
    gearcruncher likes this.
