Transfer Case Fill Plug Size
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mr Froston, Jan 1, 2019.
  1. Jan 1, 2019 at 5:57 PM
    Mr Froston
    Mr Froston [OP] Active Member
    Montana
    1998 Toyota Tacoma SR5 Extracab V6
    Hey guys,
    Just changed my transfer case oil to Redline D4 ATF. It was a pain in the butt to get the fill plug off but I got it off and changed the oil. I need to replace the fill plug ASAP and I'm having a hard time finding a replacement bolt. Any help would be very much appreciated.
    Thanks,
    Montana
  2. Jan 1, 2019 at 6:19 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    I would try your local Toyota dealer. They will most likely have it in stock.
  3. Jan 1, 2019 at 6:21 PM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    The fill and drain bolt part number is:
    90341-18006
    And the crush gaskets are:
    90430-A0003
    Mr Froston [OP] likes this.
  4. Jan 1, 2019 at 6:47 PM
    Wulf
    Wulf lost and found special
    Jake
    24400 E Smoky Hill Rd, Aurora, CO 80016
    96 Tacoma WIP
    yes
    transmission or transfer case?
    I would not run ATF in the transfer case for any extended period of time
  5. Jan 1, 2019 at 6:49 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I just noticed that he used ATF for the transfer case. That can't be good.
  6. Jan 1, 2019 at 7:00 PM
    Wulf
    Jake
    96 Tacoma WIP
    yes
  7. Jan 1, 2019 at 7:01 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  8. Jan 1, 2019 at 7:05 PM
    Wulf
    Jake
    96 Tacoma WIP
    yes
    I think it would be the same, AFAIK the transfer case internals are the same but the input shaft varies between auto/manual.
    but I am not a professional mechanic
    BartMaster1234 likes this.
  9. Jan 1, 2019 at 8:43 PM
    Mr Froston
    Montana
    My truck is MT and I did run D4 ATF in transfer case. Did I goof on that?
  10. Jan 1, 2019 at 8:47 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You're supposed to use gear oil for both, I believe the viscosity is 75W-90 as stated above.
    I know some different cars use ATF for manual transmissions. Early 2000's Ford Mustangs use ATF instead of gear oil.
  11. Jan 1, 2019 at 8:53 PM
    Mr Froston
    Montana
    I run Redline MT90 for transmission. Redline 75W30 for front and rear diff. I thought the D4 ATF would work for transfer case. Do I need to drain that quick?
    Thanks for the input here guys.
  12. Jan 1, 2019 at 8:56 PM
    Wulf
    Jake
    96 Tacoma WIP
    yes
    MT90 will make for a happy manual transmission and 75W80 is good for the diffs. Hopefully someone with the FSM can confirm but I want to say SAE75W-90 is what the tcase calls for, I think ATF is too thin.
  13. Jan 2, 2019 at 8:16 AM
    Mr Froston
    Montana
    Okay, you guys are correct. The ATF is not good for the transfer case. I called Redline and they are sending me 75W90 GL-5. Thanks for helping me out here guys. I will drain the ATF immediately. You guys saved the day.
    Thanks,
    Montana
    Dalandser likes this.
  14. Jan 2, 2019 at 9:09 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    That’s nice of then to send you the right gear oil.
  15. Jan 2, 2019 at 9:12 AM
    Mr Froston
    Montana
    Ya, but they also reccomendend the ATF for my truck's transfer case on their website and realized they messed up.
  16. Jan 2, 2019 at 9:15 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Really? That’s a big mistake on their end. Wow.
    IAMWIEB likes this.
