Transfer case fluid change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rgerrior, Jan 5, 2020.
  1. Jan 5, 2020 at 9:25 AM
    Rgerrior
    Rgerrior [OP] New Member
    Robert
    2012 Tacoma off road trd
    Non
    Had my 2012 tacoma in for an oil change. Dealer recommended I change the transfer case fluid and rear end fluid. Any recommendation on an upgrade of an after market brands. Just turned 110,000 miles Tacoma trd off road v6.
  2. Jan 5, 2020 at 9:27 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Muddycoinwash and rnish like this.
  3. Jan 5, 2020 at 9:28 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Get the front diff fluid while you are at it.
  4. Jan 5, 2020 at 9:40 AM
    EnginerdPA
    EnginerdPA Member
    Muddycoinwash likes this.
  5. Jan 5, 2020 at 9:51 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
  6. Jan 5, 2020 at 10:56 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    ALWAYS get the plug on the filler hole cracked loose before draining the gear oil. ALWAYS.
    Raylo, tacoman45, Atlas86 and 13 others like this.
  7. Jan 5, 2020 at 11:22 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Do it yourself, super easy.
    Why didn’t they also try to rape you on the front differential?
    lynyrd3, Kpatt9 and boogie3478 like this.
  8. Jan 5, 2020 at 11:48 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Any GL-5 75w90 will do just fine.
    I use mobil1 but any name brand or well established store brand would be fine.
  9. Jan 5, 2020 at 11:53 AM
    MasonSTL
    MasonSTL Well-Known Member
    Green Bay, WI
    06 TRDOR AC MT
    Mobile 1 fan here too. It is easy to change but pumping the fluid can be annoying with a cheap pump.
  10. Jan 5, 2020 at 12:20 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Plain Jane Taco likes this.
  11. Jan 5, 2020 at 2:09 PM
    Rgerrior
    Robert
    Non
    Anyone like to keep their service work done so car fax report are kept
  12. Jan 5, 2020 at 4:00 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ooof you have had the original rear diff oil in the truck for 110k miles.... i foresee pinion bearings, and ring and pinion gear replacement (if you dont catch the pinion bearings quick enough) in your nearish future.
    But yes mobil 1 75w-90 (or really any synthetic 75w-90). Front diff and tcase every 60k, rear diff every 30k. 09+ tacos regardless of package do not need LSD additive for the rear diff, but it will not hurt to run something like Mobil 1 syn 75w-90 that has it in it already.
    bowhunterRN, Snowy and 3JOH22A like this.
  13. Jan 5, 2020 at 4:10 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Don't sweat catastrophic failure just yet. If the truck has had a reasonable life with respect to towing and differential load, it should be fine.
    OP, please let us know when you change it an how the old fluid looks!
    lynyrd3 and Sig45 like this.
  14. Jan 5, 2020 at 4:12 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    2011 Tacoma TRD OR 4x4 & 2021 Tundra SR5 DC 4x4
    AVS in-channel window visors Husky Mud Guards Husky Liners X-act Contour Floor Liners Cooper Discoverer AT3 LT- 265/75/16 C Toyota 16" Black TRD Trail Team Edition Wheels Truxedo Lo Pro Tonneau Cover OEM Bed mat OEM Running Boards Marathon custom fit seat covers Front window tint Rear Leaf Spring 4 Pack - TSB Front - 5100's with stock springs set at .85" Rear - 4600's
    FTFY :D
    eherlihy and mikalcarbine like this.
  15. Jan 5, 2020 at 4:23 PM
    nd4spdbh
    SoCal
    Definitely change it OP. But dont be surprised shorly after changing it if you get rear diff noise that manifests itself into pinion bearing failure / ring and pinion bearing overwear. Pops changed my moms original rear diff fluid right around the same time due to a slight rear end howl in her 07 4runner that is probably the most lightly driven vehicle ever. Shortly after the above occurred. Reason being the sediment of the gunked up fluid was filling the pits in the pinion bearings, new fluid washed out the sediment as it should, which leads you down the path as described.
    Needless to say, regardless if its been changed or not, CHANGE IT ASAP.
    PzTank likes this.
  16. Jan 5, 2020 at 4:41 PM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Report it yourself in the Carfax app
    Kpatt9 likes this.
  17. Jan 5, 2020 at 4:45 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2019 magnetic gray DCLB
    A little tip to make life easier if you do it yourself...removing the spare tire makes it a lot easier to fill the rear diff. Maybe lube the cable etc. while you’re down there. Lots of help on here if you have questions.
    daytrader2 likes this.
  18. Jan 6, 2020 at 4:20 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    Very simple drain & fill. My 2012 2.7L I used Red Line Oil Products MT 75W-90 GL-4. Pricey, but you can find cheaper on ebay or Amazon. Toyota Owners manuals uses 75W-90 GL-4 or GL-5. If memory serves me correctly it's only about 1.1qts in transfer case. While your under the vehicle I'd change the front/rear differentials also (see owners manual). Again, simple drain & fill. I do recommend using new crush washers for each drain plug removed. They're cheap and same OEM part....
    https://www.redlineoil.com/mt-90-75w90-gl-4-gear-oil
    https://www.redlineoil.com/75w85-gl-5-gear-oil
    Blockhead likes this.
  19. Jan 6, 2020 at 4:53 AM
    intheblue25
    intheblue25 Well-Known Member
    2010 DCSB TRD Off Road
    I changed mine for the first time at around 105k, but I don't tow, when I checked the magnet on the drain plug, just a little super fine (like powdered sugar) metal. My fluid also didn't look too bad. The front diff however was black. I changed Front Diff, Transfer Case and Rear Diff in about an hour and I went super slow.
  20. Jan 6, 2020 at 5:02 AM
    Notoneiota
    Notoneiota Claud Bawls molested my cat.
    Oakdale & Grand Rapids, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    No. Dealerships don't care. They only look to see if there has been an accident so they can offer less for your trade-in. Your private citizen doesn't care if maintenance is listed on Carfax vs. a running list the owner keeps themselves. Don't overpay for work at a dealership just because you think it looks good on Carfax.
