Transfer case leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by kato, Apr 22, 2010.
  1. Apr 22, 2010 at 7:10 AM
    kato
    kato [OP] Well-Known Member
    Kelowna
    tacoma SR5
    Hi everyone, i've recently noticed a slight leak coming from the aft transfer case seal. Has anyone here ever changed one? Anything i should look out for?
    Thanks for any help you can give.
    Kato
  2. Apr 24, 2010 at 9:32 AM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Those leak all the time, so it's a pretty common problem. Usually it's the seal between the transfer case, and the adapter.
    It's a pain to do, but mostly because of the removal of the T/case. Once the case is out of the way, it's pretty easy to change out the seal.
  3. Apr 24, 2010 at 6:37 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    yep...getting the transfer case out will be the hardest part. At least its fairly light :D
  4. Apr 26, 2010 at 5:16 PM
    kato
    Kelowna
    tacoma SR5
    thanks for the feedback guys. Hopefully i will have the time this weekend to deal with it.
  5. Jun 21, 2010 at 11:05 AM
    pencap914
    pencap914 Member
    Glenn
    Chico, CA
    01 Trd 4x4
    grey wire mod, 2 wheel low mod.
    So is it usually the seal between the adapter and the T-case? I have a leak and I just cant tell where its coming from. But it looks to me like behind that adapter to t-case seal its all wet with oil.
