Transmision Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Homer623, Jul 30, 2021.
  1. Jul 30, 2021 at 11:46 AM
    Homer623
    Homer623 [OP] New Member
    Tacoma 2012 TRD
    Hi
    I am new to this forum! I just bought a second hand (or third) Tacoma 2012 TRD 4x4 with 65k miles on it.
    Last week I took it to the Toyota dealer close to my home to get a quote on a transmision oil change.
    The service manager told me that they do not change transmision oil in vehicles over 50k miles; beacause putting new oil in a greabox that has not been serviced before, might lead to failures.
    It doesn´t makes sense to me, but this is my first 4x4 truck so I would appreciate any feedback on this issue.
    Cheers!
  2. Jul 30, 2021 at 11:51 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    The dealer is an idiot and lying to you.
    You can do it yourself if you’d like. Several threads in the maintenance section.
    Rambo MARINE Recon and usmc2msu like this.
  3. Jul 30, 2021 at 11:56 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Old wifes tale that the gears get "used" to the old fluid so flushing it out with new fluid causes issues on how the gears mesh.
    pahaf, Chickenfarmer and TnShooter like this.
  4. Jul 30, 2021 at 1:05 PM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
  5. Jul 30, 2021 at 1:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Not true, I did a drain and fill at 100k.
    And guess who did it? - The dealership.
    I’d definitely recommend drain and fill at a minimum.
    The dealership probably uses a flush machine, and doesn’t want to risk flushing contaminants into the valve body. If done correctly, the likely hood of this happening is unlikely. But it’s a risk most won’t take.
    My dealership would not do a flush. They will do a drain and fill.
    To do a flush correctly involves dropping the pan, cleaning the magnets in the pan.
    Replacing the filter, and flushing the lines in the proper direction.
    FWIW, I’ll probably do my own next time.
    Drain the pan, measure what comes out, add back the same amount.
    NAAC3TACO and BlkDakDave like this.
  6. Jul 30, 2021 at 1:18 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Just to clarify, does your truck has a manual or automatic transmission? BTW-Welcome and congrats on that "new to you" Tacoma.
    TnShooter likes this.
  7. Jul 30, 2021 at 3:18 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    My toyo dealership quoted me 250 for pulling pan changing filter and fill
  8. Jul 30, 2021 at 3:20 PM
    TnShooter
    Deogee
    STOCK
    For a Dealership, that’s not bad.
    D&R only cost $194 here.
    That’s why I’ll just do my own next time.
    I may or may no go through the Temp Check process.
    Probably just measure and refill.
  9. Jul 30, 2021 at 3:22 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    The Toyota dealership that is actually closer to me quoted 425.00
  10. Jul 30, 2021 at 3:23 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
  11. Jul 30, 2021 at 3:27 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    They're just not wanting to take liability on a vehicle that hasn't had the trans serviced. What happens over time is that your clutch material wears off the bands and stays suspended in your trans fluid. This causes the vehicle to still shift just like normal (usually.) When that fluid is replaced with new fluid that no longer has all that clutch material in it, the trans which was already damaged starts to slip and show its true condition. At 65k, id think you're fine, but I would do it myself. It's simple.
    Drain the fluid and make sure it isn't black and doesn't smell burnt. If not, you're good to replace the ~3.5 quarts that you drained. (If so, put that fluid back in and just drive it.) Drive the truck 20 miles or so, and do it again. I do three dump and fills which gets you something like just under 90% all new fluid in there. Only use the appropriate toyota WS fluid imo though.
    Rambo MARINE Recon and TnShooter like this.
  12. Jul 31, 2021 at 6:20 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    This.
    If the transmission is already compromised. Or if the fluid has been allowed to get too hot in the past it is best to just leave it alone. If there is already damage changing the fluid won't fix it, in fact it will speed up transmission failure. Lots of people get their transmissions serviced and have them die within 1000-2000 miles then come back and blame the guy who did the work. No shop wants that headache.
    Leaving the old fluid in there buys you more time before the failure, often years. Even if there is no damage changing it won't extend your transmissions life anyway. With no known history on the vehicle I'd not change the fluid either. In fact I don't know of any reputable shop who will change transmission fluid regardless of miles. The un reputable ones will take your money.
    Transmission fluid doesn't serve the same purpose as engine oil. And today's transmissions, and the fluid in them, ain't the same as your grand daddy's. There is really no reason to ever change it. 95% of the vehicles built will end up in the scrap yard for other reasons before the transmission fails with the factory fluid in it. And the transmissions that die early will still die early even if you change the fluid. I know too many guys who have changed their fluid every 50,000 miles and still had them die under 200,000. And too many guys between 300,000-400,000 still running the factory fluid. They die when they die. There is no correlation between how often you change the fluid and your transmissions life. At least with vehicles built in the last 15-20 years. Forty years ago there was a need to do this.
  13. Jul 31, 2021 at 7:47 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Is it even true that the transmission will slip? I think that myth came from people back in the 90s or around then draining tranny fluid and putting in the wrong fluid. Sounds something that my dad would do. And that would cause it to slip.
    I say change your fluid. Even if you have 200k on original. Just make sure to put in correct fluid
