Transmission Coolant Line Part Needed
Discussion in '1st Gen. Tacomas (1995-2004)' started by CS_AR, Jun 16, 2019.
  1. Jun 16, 2019 at 2:23 PM
    CS_AR
    CS_AR [OP] Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Does anyone know how I can get one of these transmission coolant line connection parts?
    I don't see it on any parts diagrams. I'm at a loss for what to call it or how to get one.
    The threads are damaged on this one and it cannot be used.
  2. Jun 16, 2019 at 2:36 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    All else fails take it to your local “auto recycling” yard. See what’s in the yard. Prepare to get dirty.
  3. Jun 16, 2019 at 2:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Transmission cooler union; there are 2 of them IIRC
    Trying to find part numbers...
    CS_AR[OP] likes this.
  4. Jun 16, 2019 at 2:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  5. Jun 16, 2019 at 3:09 PM
    CS_AR
    There is a 996 listed on page 14.7 - that is the 2nd "short one" that is toward the transmission rear.
    Kwikvette[QUOTED] likes this.
  6. Jun 16, 2019 at 3:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I was going to refer you to that part, but it looked bigger than what you listed.
    It is a coolant line union though.
    Is there really no way to salvage that part? If not, find out the thread/pitch and put a different kind on that'll fit. Going that far in, you may as well install an external transmission cooler...but wanting to do that for awhile now.
    CS_AR[QUOTED][OP] likes this.
  7. Jun 16, 2019 at 4:15 PM
    CS_AR
    Will a 4Runner 1999/2000 use the same parts? There are a couple in the salvage yard.
  8. Jun 16, 2019 at 4:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Same transmission, different torque convertor, don't see why not.
  9. Jun 16, 2019 at 4:48 PM
    CS_AR
    Thank you. Looks like I will be going to the yard tomorrow.
  10. Jun 16, 2019 at 4:49 PM
    CS_AR
    There are two Tacomas in the yard too. But those are 4 cylinders - 5 lugs.
  11. Jun 16, 2019 at 4:49 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I actually ran into an issue with this part number when I was trying to find a spot to tap into for a temperature sensor.
    90407-16009 is labeled as the outlet union (the long one you have pictured), but that is actually the part number for the inlet
    90407-16012 is labeled as the inlet union, but is is the long one (outlet)
    https://www.toyodiy.com/parts/p_U_200009_TOYOTA_TACOMA_RZN161L-TRPDKAB_3514.html?hl=32921C
    You can see all of the vehicles that use that part here:
    https://www.toyodiy.com/parts/xref?s=90407-16012&mU=on
    Once you figure out how to use toyodiy.com, it's amazing.
    O-ring part number is 90301-11006
    I start talking about this here in my build thread: https://www.tacomaworld.com/threads/tiffany-the-taco.374490/page-8#post-15809328
    You can scroll down to read it all if you'd like.
    You can see the shiny silver part at the top of this pic. That part is 90407-16009. It is obviously not the long union. Please ignore the black part.
    So you want 90407-16012
    Kwikvette and CS_AR[OP] like this.
  12. Jun 16, 2019 at 5:01 PM
    CS_AR
    Thank you. I'm getting hits that 90407-16012 is for a 2000-2004.
  13. Jun 16, 2019 at 5:02 PM
    nzbrock
    Noah
    San Marcos, TX
    One is inlet, one is outlet on the A340E and A340F transmission (and probably others). Year doesn't really matter.
    CS_AR[QUOTED][OP] and Kwikvette like this.
  14. Jun 16, 2019 at 5:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Same transmission.
    CS_AR[QUOTED][OP] and nzbrock like this.
  15. Jun 16, 2019 at 5:11 PM
    CS_AR
    Thank you. I'll head to the salvage yard tomorrow.
