Transmission cooler install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ricTaco, Mar 28, 2019.
  1. Apr 3, 2019 at 10:18 AM
    dentedporsche
    dentedporsche Well-Known Member
    Ron
    Curious ... has anyone ever heard of a cooler for a manual transmission? I know that heat is the downfall for any transmission and while towing always wondered with my manual.
  2. Apr 8, 2019 at 8:56 AM
    ricTaco
    ricTaco [OP] Member
    2018 Tacoma TRD OR DCSB
    I installed a Hayden 677 in series with the OEM cooler but I still get up to 215-225F post converter temperature on climbs with the 3800 lb load although the pan temp is never much higher than 200F. Should I be paying attention to one temp more than the other?
    cryptolime and jonnytacoo like this.
  3. May 24, 2021 at 11:29 AM
    ksimms92
    ksimms92 Well-Known Member
    Kevin
    West of Chicago
    2020 Silver TRD OR DCLB 4X4
    Could I ask where you purchased the trucool from? I’m having a hell of a time finding a retailer that sells the LPD4590. I went through their list of US distributors, but not much success :angrygirl:
  4. May 25, 2021 at 10:41 AM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    You could pin the transmission thermostat open on your trips with climbs. Takes less than a minute to do.
  5. May 25, 2021 at 11:09 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    would these coolers be able to be added to the 2020+ that didn't come with any auxiliary cooler?
    jonnytacoo likes this.
  6. May 25, 2021 at 4:43 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Yep, I’m not seeing it on eBay or Amazon.
    I purchased over 3 years ago from retailer in Lakewood, Washington on eBay.
    Looks like the 4711 which requires fittings and is in stock is a bit lower on BTUs.
    ksimms92[QUOTED] likes this.
  7. Jul 25, 2022 at 7:10 AM
    jonnytacoo
    jonnytacoo Well-Known Member
    Jonny
    So Cal
    2018 TRD Off-Road 4x4
    OEM
    how did adding the cooler go? I just checked out that 679 on Amazon. I have a lot of weight and I want to add a better cooler. I do have a oem cooler right now. Highest temp I’ve seen is 208. Might be normal since I’ve been reading temps can run high but it would be nice to bring it down 20 degrees or so for fluid longevity.
  8. Jul 25, 2022 at 7:18 AM
    jonnytacoo
    Jonny
    So Cal
    OEM
    Looks awesome, was the install hard? Did it come with mounting brackets or did you have to make it custom
  9. Jul 25, 2022 at 7:26 AM
    jonnytacoo
    Jonny
    So Cal
    OEM
    Installed another cooler and temps didn’t go down?
  10. Jul 25, 2022 at 9:06 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    https://www.ebay.com/itm/322062519620?epid=17021346823
  11. Jul 25, 2022 at 9:07 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    you should be monitoring the pan temp. the post converter temp will go really high for short periods but the pan temp is what you should be monitoring.
