Transmission cooler
Discussion in 'Towing' started by Tacouser, Aug 5, 2014.
  1. Aug 5, 2014 at 7:37 PM
    Tacouser
    Tacouser [OP] Tacoma User
    Chicago area
    12 tacoma Prerunner
    Cab LED's, Color matched front grill emblem,ARE color matched hard bed cover, Audio amp and new speakers
    Question about trans coolers. So my 2012 Tacoma came with the tow package which included the supplemental trans cooler. But in 90 degree weather my trans is still hitting 190degrees, according to my scan gauge. I want to start towing a travel trailer, but the temp will be even higher. Has anyone added another trans cooler inline of the factory installed one?
  2. Aug 5, 2014 at 7:51 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    I'll be interested as well.
  3. Aug 5, 2014 at 8:09 PM
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    You may want to check your fluid level to make sure it's on spec. Make sure you use the "transmission fluid level check procedure" that you can search up on this forum, it's pretty specific since there's no dipstick on these transmissions. Mine hit 198 the other day going up a long hill, towing nothing. It never goes above 110 in winter, seems to be around 160-190 all summer. Don't forget the temp rockets up under load because the TT is right on the outlet of the torque converter where the fluid gets heated quickly under load just before hitting the transmission cooler. So the fluid doesn't stay that hot very long at all.
  4. Aug 5, 2014 at 11:13 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
