Transmission Delay Into First Gear
Discussion in 'Performance and Tuning' started by emilminasian, Jul 30, 2015.
  1. Jul 30, 2015 at 8:28 PM
    emilminasian
    emilminasian [OP] Well-Known Member
    Emil Minasian
    Glendale, CA
    2011 Trd sport double cab
    Ive been having this issue for a while and havent really figured out what might be the problem, so if im driving, and come to a red light maybe about 15 seconds into the light i feel my truck kick forward as if it just fell into first gear. Im not sure if thats what it actually is. Has anyone came across this issue or if its normal? 2011 Tacoma 2wd 71000 miles
  2. Jul 30, 2015 at 8:30 PM
    HiFire
    HiFire Well-Known Member
    Eric
    Hawaii
    SR5,4x4,DCSB,Auto
    Weathertech mats, BAMF sliders, US Offroad front winch bumper, RCI Alum. Skid plates, ICON suspension, Pelfreybilt rear bumper, JBA uca's, Allpro u-bolt flip,
    A/C compressor kicking in?
  3. Jul 30, 2015 at 8:33 PM
    emilminasian
    Emil Minasian
    Glendale, CA
    AC is usually off
  4. Jul 30, 2015 at 9:35 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    At idle at the light you are in first gear I think. Changes in the tach? Monitor and post on that. DBL check the AC, you say it's 'usually' off.
  5. Jul 30, 2015 at 10:28 PM
    emilminasian
    Emil Minasian
    Glendale, CA
    What does it mean to change in the tach
  6. Jul 30, 2015 at 10:40 PM
    emilminasian
    Emil Minasian
    Glendale, CA
    Is it Something bad? Or dangerous ? Fix able?
  7. Jul 31, 2015 at 1:14 AM
    emilminasian
    Emil Minasian
    Glendale, CA
    I have AAL but no blocks and stocks rear shocks
  8. Jul 31, 2015 at 2:15 AM
    gearcruncher
    Canadain bumper technician
    The op says he is sitting at the light for 15 seconds . Thats not axle wrap ,He is feeling the famous Toyota throttle bump .
  9. Jul 31, 2015 at 7:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There have been a rash of Tacoma's which have been recalled for the Automatic transmissions being under filled from the factory. Sounds like your fluid level should be checked.
  10. Jul 31, 2015 at 8:34 AM
    gearcruncher
    Thats very true and i agree with you but usually when we
    have an axle wrap problem , the vehicle will unload the energy upon an initial stop or
    during first accelaration . The way i understand his concern is a bump while sitting at a stop .
  11. Jul 31, 2015 at 9:11 AM
    emilminasian
    Emil Minasian
    Glendale, CA
    So I should check my transmission fluid! Should I have any other concerns ?
  12. Jul 31, 2015 at 11:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @Lucario Runner , just recently replaced his family member's transmission . Due to a low factory fill.
    Checking you fluid level is free and easy. Plenty of Inc on this forum on how to do it. It is worth the piece of mind? Yes.
    You said you have AAL's. Did you tighten all of the leaf spring bolt while the truck was jacked up, or sitting on the ground under its own weight?
  13. Sep 7, 2015 at 9:36 AM
    Onelimerick
    Onelimerick New Member
    I have a 2011 Pre Runner with the same issue. It started around the 36000 mile mark. It has gotten worse over time. It also seams to be more prevalent when the weather is cold. I have checked the transmission fluid and it was
    at the proper level (boy I miss a dipstick!). I do not notice a change in RPMs when it occurs.
