Transmission Fluid Change
Discussion in '1st Gen. Tacomas (1995-2004)' started by tClay07, Jan 15, 2014.
  1. Jan 15, 2014 at 6:30 PM
    tClay07
    tClay07 [OP] Member
    Tyler
    California
    03 Tacaoma 4x4 5spd V6 TRD
    So I am going to change my transmission fluid here in the next couple days or so and was wondering if it is just like the front/rear diff and tranfer case where you just pull out the fill plug, then the drain plug then fill it back up or if there was more to it. Any ideas? Thanks
    PS- it's an 03 with a MANUAL transmission
  2. Jan 15, 2014 at 6:57 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; mattgecko's Underhood Lighting; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    In a word, yes. The process mirrors what you do for the differentials and the transfer case. Don't forget to replace your crush washers.
  3. Jan 15, 2014 at 9:22 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    02 Dbl cab Lunar Mist
    Some of this Some of that
    It is basically the same yes. Automatic transmission is different with more steps
  4. Jan 15, 2014 at 10:47 PM
    tClay07
    tClay07 [OP] Member
    Tyler
    California
    I'm just curious... What would happen if I didn't change the crush washers?
    Thanks
  5. Jan 15, 2014 at 11:17 PM
    grovestreet
    grovestreet Well-Known Member
    Flip the gasket and use a torque wrench. Probably fine but why risk it.
  6. Jan 15, 2014 at 11:19 PM
    Norton
    Potential for leaks. They are CHEAP insurance.
  7. Jan 16, 2014 at 5:44 AM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    Clemson
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Window Rain Guards Bed Liner Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges
    the manual has the amount of fluid you need in the specs section so you know how much to buy. i wouldn't bother with the crush washer replacement if its inconvenient for you. the plugs will keep oil from leaking with only a few threads engaged, so having it tight with the same washer is more than adequate.
    i also wouldn't worry about torquing it down to something specific. just hand tight. it isn't critical to meet a torque rating for these plugs like you would for a lower ball joint.
  8. Jan 16, 2014 at 8:42 AM
    egebhardt
    egebhardt Well-Known Member
    Eric
    San Carlos, CA
    '99 4x4 Xcab 5spd V6
    None
    I just did this job 2 nights ago.
    Valvoline 75w-90. 7 bux a quart. Non-synthetic for me because I flush every 2 years, no matter what. Fresh oil trumps fancy oil.
    I have the same tranny. Mine took 2.7qts. The manual said 2.3. IDK why.
    Just drain and refill.
  9. Jan 17, 2014 at 8:09 PM
    tClay07
    tClay07 [OP] Member
    Tyler
    California
    So I changed my fluid today and I open the fill plug and tons of fluid started pouring out. Is that normal?? Anyway, there was over 3 quarts that drained but I got the 2.3quarts in (like the manual said) until it flowed out of the fill plug. Does that sound like I did it right?
  10. Jan 18, 2014 at 12:30 AM
    Norton
    Not normal, in my experience. Sounds like it was previously over-filled.
    Yes - the process you used sounds correct.
