Transmission fluid??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Junetaco03, Aug 21, 2017.
  1. Aug 21, 2017 at 9:28 PM
    Junetaco03
    Junetaco03 [OP] Well-Known Member
    california
    TRD limited
    ARB bull bar bumper, led lights, 8000lb winch, factor 55, trd headers
    I'm running low on transmission fluid. Never added this before wondering which one I should buy ? I have a 2003 tacoma v6 3.4. Thanks
  2. Aug 22, 2017 at 12:32 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    2000 Work truck
    Super Springs
    Well since you said Fluid
    It calls for Toyota T-IV ATF
    Which seems to open up a whole can of worms as to just what else can be used.
  3. Mar 14, 2019 at 3:59 PM
    Zerofear66
    Zerofear66 Active Member
    2002 Tacoma PreRunner,2014 Tundra CrewMax TRD 5.7L
    Is there any thing else that can be safely used?
    I did a search but couldnt find much.
    TIA
  4. Mar 14, 2019 at 4:10 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    I would tend to want to figure out why I'm running low on transmission fluid, first...
    Wyoming09 likes this.
  5. Mar 14, 2019 at 4:22 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Brock
    Louisiana
    2001 Green Double Cab 4x4
    OME 881/5100 combo w/ Toytec AAL & BFG KO2's
    This is what I use. It seems to be pretty good stuff
    jeg0005 and RonJon31 like this.
  6. Mar 14, 2019 at 6:45 PM
    Martman
    Martman Member
    Martin
    Regina Saskatchewan canada
    1998 tacoma SR5 TRD 4x4.
    None
    Why not go to toyota and get the factory stuff..
  7. Mar 14, 2019 at 8:24 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    BTW Your dipstick always specifies what type of oil/fluid goes there.
  8. Mar 15, 2019 at 10:09 AM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    None (yet)
    Second this.
  9. Mar 15, 2019 at 12:34 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Everything
    Factory fluid costs way too much. I third what the others said.
    Rachelsdaddy likes this.
  10. Mar 15, 2019 at 1:05 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    99 tacoma 4x4 2.7
    I just looked at the price of the Toyota IV atf.... holy crap, 10-15 a quart on EBay. I planned on changing mine this spring but will be looking at other options for sure
  11. Mar 15, 2019 at 1:29 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Toyota doesn't make transmission fluid and as far as I know use no material in their tranny that requires a formulation that no one else uses.
    I actually think factory spec oils are on the low end.
    Luv my yota and Rachelsdaddy like this.
  12. Mar 15, 2019 at 1:33 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Read your dipstick, possible you don't even use T-IV (I don't know personally but Toyota was using Dex III in 99 for my Sienna)
  13. Mar 15, 2019 at 1:39 PM
    Rachelsdaddy
    99 tacoma 4x4 2.7
    I will be checking for sure as I don’t even know what tranny is in it since someone long ago appears to have replaced it. *sigh... It is a PreRunner with gender issues that now identifies as a 4x4. I think it’s right since the ECT button and OD buttons work properly.. lol ehhhh but I noticed some stuff under there that don’t look original such as the dipstick tube bracket has nothing to bolt to, The cooler lines are kinda mickey moused. Thanks for the heads up.
