Transmission Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by turkinator, Feb 5, 2021.
  1. Feb 5, 2021 at 3:36 PM
    turkinator
    turkinator [OP] Well-Known Member
    Ray
    SW Ohio
    2015 TRD sport double cab long bed
    Fiberglass shell level 17” wheels
    I just bought this 15. It has 39,000 miles on it. Do you think changing the transmission fluid would be a good idea?
  2. Feb 5, 2021 at 3:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Well......It isn’t a bad idea.
    If it has OEM WS fluid, it is probably a better idea.
    “(6)Why does Aisn Warner who make the transmission say that the transmission fluid needs to be changed every 30 k and 25 k under severe......”
    https://www.tacomaworld.com/threads...e-get-it-out-of-your-transmission-now.331521/
    Now that I gave you the best answer that I know.
    I will tell you, I didn’t follow that maintenance advice.
    Mostly because I didn’t know any better, and I did drain and fills.
    I am still running WS :eek:
    Rick's 2012 likes this.
  3. Feb 5, 2021 at 3:44 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Uh... YEAH...
    Actually that's about the perfect time to change, schedule IIRC is roughly 4 years/40k miles so you're under on miles but over on time. Time to change. I'd recommend doing it yourself at home as two separate drain and fills rather than shelling out the big bucks at a service center to get it "flushed".
    TnShooter likes this.
  4. Feb 5, 2021 at 3:50 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    This just reminded me to do the wife’s car this weekend. I think the range on the at is fairly large. 30,000-60,000 I think so your in the middle but check on those numbers i could be wrong.
  5. Feb 5, 2021 at 3:58 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    You don't know how the truck was treated. Change the tranny fluid. Drain and fill :thumbsup:
    Key-Rei and TnShooter like this.
  6. Feb 5, 2021 at 3:58 PM
    turkinator
    Ray
    SW Ohio
    Thanks all!!!
  7. Feb 5, 2021 at 4:07 PM
    machineman89
    machineman89 Well-Known Member
    Matthew
    San Leandro
    overlanding limo in progress :-P
    Weather tech floor mats, fog light any time mod, derped front embelem, Pelfretbilt 3 hoop plate bumper, 10k warn xeon winch-s some leds, pelfreybilt roof rack, scs stealth series rims, wrangler authority tires, BAMF 96" bolt on sliders, BAMF dif skid, some dirt....
    ......drain and fill before 100k?...........oops
    '01runner likes this.
