transmission fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDsport253, Feb 9, 2010.
  1. Feb 9, 2010 at 6:16 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you can do either.i drain and fill mine every 15k.some people wait till the fluid looks like tar ,and then they flush to try to get all the burnt fluid out. if you keep it clean you want have to flush,but thats up to you.
  2. Feb 9, 2010 at 7:38 PM
    TRDsport253
    TRDsport253 [OP] Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    must of missed that dam. Thanks for the link
  3. Feb 9, 2010 at 8:26 PM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    so I take it that WS fluid is preferred but type 4 fluid is okay to use. I'm I wrong?
  4. Feb 9, 2010 at 8:58 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    I think its time for a flush!!
  5. Feb 11, 2010 at 4:21 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    WS fluid is for the 5 speed automatic found with the V6
    Type IV fluid is for the 4 speed 2.7 liter four cylinder
    DO NOT MIX ONE FOR THE OTHER
  6. Feb 11, 2010 at 5:07 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    +1
  7. Mar 21, 2011 at 5:48 AM
    looneytunemagoun
    looneytunemagoun Well-Known Member
    james
    Leicester,mass
    SR5
    what about royal puple is it safe to use i got 2008 just got it wait to change all fuildes
  8. Mar 21, 2011 at 5:55 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    had mine done at 50k.....they informed me it didnt need it till 100k.....i said idgaf change it!....now i should be good till 150k!!
    jonnytacoo and TacoTuesday!! like this.
  9. Mar 21, 2011 at 8:53 AM
    Back40
    Back40 Well-Known Member
    SC
    2005 4x4 Dbl Cab
    I flushed mine myself @ 60k for only the cost of 11 qts of WS. Will do again @ 120k.
    jonnytacoo likes this.
  10. Jan 24, 2013 at 5:21 AM
    mnerren
    mnerren 2006 Tacoma TRD Sport XSP
    Jacksonville, FL
    2006 Tacoma TRD Sport Double Cab
    It doesn't need flushing, flushing will do more damage than good. And if you aren't towing very much, it probably will never need changing. If you tow a lot, just drain and fill the amount that came out. Or, waste your money and do whatever. The interval to change is still 120,000 and that is only if you are doing a lot of towing.
  11. Mar 14, 2013 at 1:27 PM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    You might want to check those figures. The drain/fill interval, per Toyota, is 60K. The local dealers verified this - they asked questions like: tow anything? Driven on any dirtroads? etc., and said that 60K is recommended. So, as another poster said in another thread - if it makes you happy to cut corners in maintenance, then no one's stopping you...I, however, will still to factory recommended maintenance levels on mine...
  12. Apr 2, 2013 at 1:40 AM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    I had Gregs japanese auto do a transmission fluid drain and fill on my truck. It appears to shift smoother could just be my head.
  13. Apr 2, 2013 at 7:11 AM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    Read the maintenance book. my 2012 says at 60,000 tranny flush using only toyota WS fluid
  14. Apr 2, 2013 at 4:46 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Valvoline Maxlife is "WS" spec'd. It is a hell of a bunch cheaper.
    dpf88101 likes this.
  15. Apr 7, 2013 at 11:44 PM
    #35
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    Mine just say when deemed necessary.
  16. Jul 8, 2014 at 12:23 PM
    #36
    jackbower6864
    jackbower6864 Member
  17. Jul 8, 2014 at 9:54 PM
    #37
    pinktaco808
    pinktaco808 Hot Steppa
    anyone got a how to for the 2.7 4 banger auto
  18. Jul 9, 2014 at 5:08 AM
    #38
    SpacemanSpiff
    James
    08 TRD Off-road
    Search for Mountain Lion's and Fortech's write-ups on this issue. Off the top of my head, I don't remember which one did the drain/fill and which did the flush. Both are excellent write-ups!
  19. Jul 15, 2014 at 12:14 PM
    #39
    pinktaco808
  20. Jul 15, 2014 at 12:27 PM
    #40
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    Very nice write up.
