Transmission flush on 2008 prerunner 2 wheel drive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joeortego, Mar 2, 2013.
  1. Mar 2, 2013 at 7:16 PM
    joeortego
    joeortego [OP] Member
    Joe
    Texas
    08 Tacoma PreRunner
    I have seen alot of procedures for the 4 wheel drive models with the trans. temp light. But mine does not have the light how do you know when to check it????
  2. Mar 2, 2013 at 7:19 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    I don't use that method. I wait till it gets up to operating temp, then do the filling procedure.
  3. Mar 2, 2013 at 7:20 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    It still works the same way. Your truck has the temp light it just does not light up until you do the procedure to check for temp. I've done it multiple times on trucks at my work.
  4. Mar 2, 2013 at 7:34 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    That's wrong. If truck is at operating temp than you are to high.
  5. Mar 2, 2013 at 7:44 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Too high? I don't smoke sir.
    Depends who you talk to. I've heard licensed Toyota techs say operating temp is fine.
  6. Mar 3, 2013 at 12:55 PM
    BlueT
    NorthEast
    Sadly I believe you. I had to fix my wife's truck, transmission fluid level was low, after Toyota service. I realized because transmission was slipping when cold going uphill. If you set level at full temp, on cold days when you start truck it will be pumping air into torque converter. This not a problem for people living in warmer places since temp difference is not as brutal and tranny warms up almost immediately. For the rest of us in colder climate that is problem. Removing dipstick from tranny was stupidest thing ever by toyota.
  7. Mar 3, 2013 at 1:32 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    ^^this^^
