Transmission issue when putting truck into drive?
Discussion in 'Technical Chat' started by CRiz, Oct 17, 2013.
  1. Oct 17, 2013 at 12:35 PM
    CRiz
    CRiz [OP] Well-Known Member
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Hey guys, I have a issue with my truck that sometimes when I put the truck in drive and I let of the brakes the truck doesn't move. I have to give the truck has for it to start moving again and when it does the truck kind of jumps and you hear a thump. Everything else seems to be normal with the transmission expect for that issue! The truck shifts fine and doesn't seem to have any other problems with transmission. I haven't check any of the transmission fluids and I haven't check any mounts either cause I'm unsure on how to do it!
    Any help will be appreciated thank you!
  2. Oct 18, 2013 at 9:38 AM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Anyone?
  3. Oct 18, 2013 at 9:39 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Do you have your parking brake on?
  4. Oct 18, 2013 at 11:41 AM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    No the parking/emergency brake isn't on as far I know. It is pubs all the way back and should be disengage
  5. Oct 20, 2013 at 9:11 AM
    AKTacoParty
    AKTacoParty Well-Known Member
    Jake
    Astoria, OR
    2013 DCLB
    885s, Dakars, Bilsteins, Allpro Sliders, Archive Garage Hammer Hangers, Wheelers Ubolt flip, super bumps, RCI front skid
    There is no dipstick for trans fluid level? I know the 2nd gens are sealed, but yours might have one. You should definitely check the level. Also take notice of color and smell.
  6. Oct 20, 2013 at 9:18 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Has the truck ever done this when you don't use you're e brake at all? Sounds to me like the ebrake isn't disengaging all the way.
  7. Oct 20, 2013 at 9:21 AM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    The few tacomas I have driven do this, all 2nd gen autos. The truck hesitates for a second before it feels like it engages. Most noticeable when shifting from R into D.
  8. Oct 20, 2013 at 9:27 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    what?
  9. Oct 20, 2013 at 10:13 AM
    Nixinus
    Oregon
    2010 4x4
    It Is my understanding that it is a safety feature to prevent damage from quick shifts but shouldn't lag or be unresponsive for more than a second at worst, most of the time it is just a split second.
  10. Oct 20, 2013 at 10:15 AM
    Nixinus
    Oregon
    2010 4x4
  11. Oct 20, 2013 at 11:03 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I've never noticed it before. However I don't think it applies to the OP because I think this is something new that he is noticing:confused:
  12. Oct 21, 2013 at 7:32 AM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    The problem is only sometimes. I never. Used the e-brake. It happens sometimes, and it's just when I take the truck out of park and put it into drive, and let go of the brake the truck won't roll like it normally does. So I have to give it some gas and then it feels like it pops into gear and the whole truck kind of jumps.
