Transmission issue ?
Discussion in 'Technical Chat' started by durf4694, Jan 23, 2014.
  1. Jan 23, 2014 at 5:45 AM
    durf4694
    durf4694 [OP] giggity giggity
    ny
    06 tacoma sport
    K&N cold air kit, Kenwood double din with dvd player, navigation, rear cam. hook up with One JL 12" sub powered by a 800 watt pioneer amp, Sirius/XM satellite radio, TRD Neoprene Seat covers, Tinted windows all around, Trifecta Tonneau Cover, Billies at 1.75 and a 1.5 block in the back
    Driving to work today my tranny was slipping in 1-2 gear. Got to work and went for reverse and it wasn't there, then drive wouldn't work so I put it in 3rd and it crawled forward so i could get it outta the way. It didn't make any big noises. Any ideas beside a f'ed tranny
  2. Jan 23, 2014 at 5:53 AM
    gearcruncher
    Canadain bumper technician
    Check trans fluid first . Unusual for both forward ranges and reverse range to go all at once
  3. Jan 23, 2014 at 5:57 AM
    durf4694
    ny
    06 tacoma sport
    Oh and it's 5 degrees out with negative windchills, 130k, and never flushed transmission since first couple years of dealer maintenance.
  4. Jan 23, 2014 at 5:58 AM
    durf4694
    ny
    06 tacoma sport
    Alright, think trying to drive it home would be a mistake ? 25 miles. If it even moves after I get outta work to see if it's alive.
  5. Jan 23, 2014 at 6:02 AM
    gearcruncher
    Big mistake !
    check fluid first . $50 bucks worth of fluid is cheaper than $3000 for trans overhaul .
  6. Jan 23, 2014 at 6:10 AM
    durf4694
    ny
    06 tacoma sport
    Alright, there's a Napa next to my work. I've heard rumor you 'have' to use Toyota Fluid.. It'd be nice if the transmission had a dipstick. Never checked it before
  7. Jan 23, 2014 at 6:14 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Let it run and warm up then pull the check plug on the tranny pan, it should drip out or be right at the plug. I doubt (unless you specifically told them) that your tranny fluid was ever changed/flushed. The auto Trans uses WS atf fluid. Your best non OEM fluid would be Valvoline MaxLife, it's WS compatible.
  8. Jan 23, 2014 at 6:32 AM
    durf4694
    ny
    06 tacoma sport
    Alright thanks ! What side is the plug on ? Front or back ?
  9. Jan 23, 2014 at 6:33 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    I would say its time for a COMPLETE flush, not just a trans drain and replace.
  10. Jan 23, 2014 at 6:40 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    That's from the Full flush thread, Make sure you pull the "sunken in plug" (the forward one) that's the Check level plug. Get it filled up to get it home and then soon I would recommend you do the full flush. I've got 120k on mine and acquiring stuff for the flush.
  11. Jan 23, 2014 at 7:17 AM
    durf4694
    ny
    06 tacoma sport
    Yeah I know. Will probably make worse as I've heard.
  12. Jan 23, 2014 at 7:23 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Make it worse by dislodging "chunks"? I think that is more from a forced flush. The full flush described in the linked thread is nothing more than letting the transmission normally pump the fluid out and then manually pump fluid into the pan. I don't believe this method will make anything worse.
  13. Jan 23, 2014 at 7:26 AM
    durf4694
    ny
    06 tacoma sport
    Thanks again sandman !
  14. Jan 23, 2014 at 7:27 AM
    durf4694
    ny
    06 tacoma sport
    I got ya, yeah your right
  15. Jan 23, 2014 at 9:12 AM
    durf4694
    ny
    06 tacoma sport
    Lunch time update ! Leaking tranny fluid up front somewhere. Dripping on ground beneath the battery side of front of truck. Will not shift into any gears or 4x4
  16. Jan 23, 2014 at 9:16 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    No bueno, check the hoses and where it goes into the Radiator/Trans cooler.
  17. Jan 23, 2014 at 9:32 AM
    durf4694
    ny
    06 tacoma sport
    At least I shouldn't need a whole tranny rebuild.... I think.
  18. Jan 23, 2014 at 9:37 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea, I don't think that being low on fluid would hurt anything badly.
  19. Jan 23, 2014 at 5:22 PM
    durf4694
    ny
    06 tacoma sport
    Truck just got a AAA ride home. I need a little advice possibly. The tranny hose coming from the top of the radiator was rotted out where it connects to the steel line. It has some wierd fitting on it not just a rubber over the steel line like the others. Is it some kind of restrictor ?
  20. Jan 23, 2014 at 5:27 PM
    durf4694
    ny
    06 tacoma sport
    We'll cancel that. It was corrosion. The steel line rotted in half
