Transmission issue ?
Discussion in 'Technical Chat' started by durf4694, Jan 23, 2014.
  1. Jan 23, 2014 at 5:46 PM
    durf4694
    durf4694 [OP] giggity giggity
    ny
    06 tacoma sport
    K&N cold air kit, Kenwood double din with dvd player, navigation, rear cam. hook up with One JL 12" sub powered by a 800 watt pioneer amp, Sirius/XM satellite radio, TRD Neoprene Seat covers, Tinted windows all around, Trifecta Tonneau Cover, Billies at 1.75 and a 1.5 block in the back
    Ok so now I have no idea how much fluid I have lost. Should I just fill through the fill plug till it leaks out the check plug ??? A response soon would be great so I can get this back together
  2. Jan 23, 2014 at 5:55 PM
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    Basically use the steps in the full flush thread. Start it, bring it up to temp (atf light on dash method), open the check plug, fill through the fill plug until it's a steady dribble coming out the check plug. Read up on the thread to make yourself more aware.
  3. Jan 23, 2014 at 6:03 PM
    durf4694
    ny
    06 tacoma sport
    Can I just fill it cold till it dribbles out the check plug. Can't let the truck run in my garage for 20 minutes. It's 0 degrees outside. I've been reading a lot of the threads just unsure bc i dunno how much fluid I lost
  4. Jan 23, 2014 at 6:05 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    The only accurate way is while it's running, pumping the fluid through the trans. The Full flush thread is the best thread I've seen to add more fluid that the 2/3qts in he pan (drain and fill).
    Full flush thread - http://www.tacomaworld.com/forum/showthread.php?t=68462
  5. Jan 24, 2014 at 2:22 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    Was it warm enough to work? You get it filled up?
  6. Jan 24, 2014 at 2:22 PM
    33yrsoftoys
    33yrsoftoys Well-Known Member
    joel
    mid Michigan
    2013 dc sport 4.0 6 speed manual
    Bilstein 5100's, front at 1.75", procomp 1" block rear, Lund ventvisors, Lund black pearl trifold tonneau, weathertech digital mats, yellow wire mod. Bfg at ta ko's 275/70r17.
    The reason for the drive-neutral 3 times is to TRY and get as much fluid out of the torque converter as possible. Its actually a good idea, but take it easy, you don't want to burn your clutch PACs. The main thing is to get the proper fluid level and not to overfill. If it runs properly after the fluid level is back to normal you should be good to go till warmer weather. Hope this helps.
  7. Jan 24, 2014 at 2:25 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    I beg to differ. It's actually to put the truck into the "ATF Temp Light Mode".
  8. Jan 24, 2014 at 3:04 PM
    durf4694
    ny
    06 tacoma sport
    Hey just putting the new fluid in now. I put oil in till it start coming out the check plug then started it and let it idle then shut it off and checked plug again. Nothing was coming out so based another court and started it and it didn't come out the plug again. I'm up to 4 courts now. I haven't moved it yet
  9. Jan 24, 2014 at 3:17 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    You're supposed to check it with it running.
  10. Jan 24, 2014 at 3:20 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    Give the second thread I posted a read. (atf temp light mode)
  11. Jan 24, 2014 at 3:43 PM
    33yrsoftoys
    joel
    mid Michigan
    I stand corrected. We used to do that to cycle the fluid out of the converter. I think that's what Toyota's doing with their atf temp check. Cycling the fluid out of the converter to get an accurate temp. Makes sense. I've only owned manuals with my Toyota's but did make my living as a major trans tech for gm. Again was just trying to help.
  12. Jan 24, 2014 at 3:53 PM
    durf4694
    ny
    06 tacoma sport
    I did check it when it was running after the 3rd court. After 5 courts and trying to get the truck in a/t check temp mode still nothing coming out of the check plug. Going to get more oil now. I couldn't get the truck in temp check mode , it's f*cking 2 degrees out
  13. Jan 24, 2014 at 4:02 PM
    Drich
    Drich Member
    Derek
    Albany
    08 TRD sport super white
    I would grab the amount of fluid it takes to fill the tranny. It is always easier to return fluid then going back and forth. A transmission usually takes a while to get up to temperature especially if it is 2 degrees out and your just letting idol not driving it.
  14. Jan 24, 2014 at 4:32 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    That's nucking cold, I think its a toasty 20* here. I wouldn't be surprised if it takes close to 10qts to get you back in business.
  15. Jan 24, 2014 at 5:02 PM
    #35
    33yrsoftoys
    joel
    mid Michigan
    Derek is right, so is sandman. Get all the fluid you need and fill it while its running if you can. It won't even test for temp until fluid is in contact with the temp sensor. With an overfill plug you don't have to worry about overfilling it.
  16. Jan 24, 2014 at 6:11 PM
    #36
    durf4694
    ny
    06 tacoma sport
    Well I took it for a drive and it shifted great. I got 6 quarts in and after I brought it back I pulled the check plug ( while running) and a good stream came out then it slowed down and just before it trickled I capped it. I should be ok if it came out the check plug
  17. Jan 24, 2014 at 6:40 PM
    #37
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    Sounds like you're good! I hope everything else is good. :thumbsup:
  18. Jan 25, 2014 at 4:26 AM
    #38
    Drich
    Drich Member
    Derek
    Albany
    Good to hear man. Hope it all works out I'm not sure where in NY your located but Albany NY is the same temp and it needs to warm up have things to do!
  19. Jan 25, 2014 at 5:05 AM
    #39
    gearcruncher
    Canadain bumper technician
    Good Gawd !!!!
    6 quarts to fill that critter back up . Musta been running low for a while or low on fluid directly from the factory . Sooo much for my estimate of $50 bucks to get you running again . I guess it beats the heck outta $3000 for a new trans .
    I bet you would be interested in an aftermarket filler tube and level indicator .
    Just pop the hood and check / fill the transmission like the old days .
    When summer rolls around , you may want to pop the transmission pan off and make sure the trans is clean .
    Waiting to service mine but its - 50 below where I live
  20. Jan 25, 2014 at 8:28 AM
    #40
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Dont worry about temperature check mode. Its more for under filling when your truck goes over 111F ...
    If you do the check when your truck is at 10F its still good.
