Transmission issue ?
Discussion in 'Technical Chat' started by durf4694, Jan 23, 2014.
  1. Jan 25, 2014 at 8:29 AM
    #41
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Hey can you post a picture which line rotted out ?
  2. Jan 26, 2014 at 7:03 PM
    #42
    durf4694
    durf4694 [OP] giggity giggity
    ny
    06 tacoma sport
    K&N cold air kit, Kenwood double din with dvd player, navigation, rear cam. hook up with One JL 12" sub powered by a 800 watt pioneer amp, Sirius/XM satellite radio, TRD Neoprene Seat covers, Tinted windows all around, Trifecta Tonneau Cover, Billies at 1.75 and a 1.5 block in the back
    Yeah I can tomorrow. It's the one that goes from the top of the radiator into the steel lines then back into a rubber hose to the trans.
  3. Jan 26, 2014 at 7:09 PM
    #43
    durf4694
    ny
    06 tacoma sport
    Yeah I wouldn't mind checking one of those out for sure, had one of those on my old 90' GMC short box. I should pop the pan off but I just dumped new fluid in so I'll run it for a little bit then probably do a flush of some sort.
  4. Jan 26, 2014 at 7:16 PM
    #44
    durf4694
    ny
    06 tacoma sport
    Here's the line
    ?attachmentid=253218&stc=1&d=1390792486"]http://www.tacomaworld.com/forum/attachment.php?attachmentid=253218&stc=1&d=1390792486[/URL]
  5. Jan 26, 2014 at 7:20 PM
    #45
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Don't change fluids. Use Toyota fluid not the aftermarket stuff.
  6. Jan 26, 2014 at 7:26 PM
    #46
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Problems with the maxlife ws compatible?
  7. Jan 26, 2014 at 7:31 PM
    #47
    gearcruncher
    Canadain bumper technician
    Back that up with some reputable information this time
  8. Jan 26, 2014 at 7:33 PM
    #48
    Spoonman
    Jamie
    Alberta
    The fibers inside the transmission soak up the fluid that first is used in the transmission. Different fluid provide a different coefficient of friction. Using aftermarket fluid can cause the plates and fibers to begin slipping. I'm really against switching fluids unless the transmission has been rebuilt(and torque converter flushed or replaced).
  9. Jan 26, 2014 at 7:48 PM
    #49
    Sandman614
    Tim
    '06 SR5 Off Road
    Hmm, haven't heard that argument before. There are several members using maxlife ws compatible without issue. After reading there reports I would use it myself. Especially in "emergency/drastic" situations.
  10. Jan 26, 2014 at 8:21 PM
    #50
    Spoonman
    Jamie
    Alberta
    Use whatever you want :D
    But in the case of different fluid fixing a slipping condition...pretty far out.
  11. Jan 26, 2014 at 8:32 PM
    #51
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    :jerkoff:
  12. Jan 26, 2014 at 8:53 PM
    #52
    gearcruncher
    That does stand to reason .
    Been talking with the guys at TRNI ( transmission rebuilders Network ). I will pass it by them
    Edit : i was replying to Spoons quote about the clutch fibers soaking in World Standard fluid on initial break in . Im not a fluid lab technician . Spoon makes a good point mind you .sort of like two different types of sand paper fighting each other . I have never sent clutch lining away to be analized after mixing fluids .
    We do however know that Valvoline Max life is endorsed by Toyota to meet or exceed the friction modifiers of WS . And we do have proof that Max life exceeds the WS coefficient of friction .
    To play it safe for now , I would be replacing all the fluid rather than mixing the two fluids together .More to come when the guys get back to me at TRNI :
    There are 11 duties of transmission fluid beleive it or not . I can only remember a few .
  13. Jan 26, 2014 at 9:02 PM
    #53
    Sandman614
    Tim
    '06 SR5 Off Road
    Who's fixing a slipping condition? OP had a line blow and pissed out around 6 quarts.
