Transmission issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oz123456789, Jul 10, 2017.
  1. Aug 7, 2017 at 7:57 PM
    #41
    Oz123456789
    Oz123456789 [OP] Well-Known Member
    Ozzzzz
    1995 Tacoma
    What type of oil would I use when I do a transmission oil change? I heard of red line Mt 90 or something like that but I wanted yall opinion..would I use the same for the transfer case?
  2. Aug 7, 2017 at 8:51 PM
    #42
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Not answering til I see pics of the clutch
    jk. Lots of people on here like redline mtl. I think they use mt90. Basically the general consensus is to use a gl-4 75-90 or 80-90 (I believe). Gl-5 is prone to degrading brass (which part of your syncro is made of)
    Currygoat likes this.
  3. Aug 7, 2017 at 9:47 PM
    #43
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
  4. Aug 7, 2017 at 10:20 PM
    #44
    Mark D.
    Mark D. Well-Known Member
    '96 base 4 cylinder Tacoma standard bed
    Added ARE fiberglass raised cap & Sony CD head-unit w' aux-input
    My '96 Tacoma owner's manual calls for Multipurpose gear oil (NOT hypoid gear oil) GL4 or GL5, 75w90.
    After my recent clutch job, I refilled with CarQuest full synthetic GL-5/MT-1 75w90 from Advance Auto Parts.
    Happy Motoring, Mark
  5. Aug 17, 2017 at 9:22 AM
    #45
    Oz123456789
    Ozzzzz
    1995 Tacoma
  6. Aug 17, 2017 at 9:23 AM
    #46
    Oz123456789
    Ozzzzz
    1995 Tacoma
  7. Aug 17, 2017 at 9:23 AM
    #47
    Oz123456789
    Ozzzzz
    1995 Tacoma
  8. Aug 17, 2017 at 9:24 AM
    #48
    Oz123456789
    Ozzzzz
    1995 Tacoma
  9. Aug 17, 2017 at 9:25 AM
    #49
    Oz123456789
    Ozzzzz
    1995 Tacoma
  10. Aug 17, 2017 at 9:26 AM
    #50
    Oz123456789
    Ozzzzz
    1995 Tacoma
  11. Aug 17, 2017 at 9:26 AM
    #51
    Oz123456789
    Ozzzzz
    1995 Tacoma
    I switched everything out. Sorry I posted this late but these are the pictures..Enjoy haha
    BassAckwards likes this.
  12. Aug 17, 2017 at 12:29 PM
    #52
    FirstTimeFirstGen
    David
    Pacifica
    wow, down to the rivets. That's some serious wear lol
  13. Aug 18, 2017 at 9:15 AM
    #53
    Mark D.
    Mine was just barely slipping. No 'chunks' missing and both it and the flywheel looked just fine. Suspect the pressure-plate spring started to fail, but it's landfill now!
  14. Aug 18, 2017 at 9:48 AM
    #54
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    ouch...
  15. Aug 19, 2017 at 10:11 AM
    #55
    Oz123456789
    Ozzzzz
    1995 Tacoma
    Quick question for yall, the brakes seem to be sticking..I bought new calipers for it but I still get a little stick, what do I need to do?
  16. Aug 19, 2017 at 11:45 AM
    #56
    Mark D.
    If you didn't get replacement calipers with the mounting brackets, check that the sliding pins aren't sticking or seized in the brackets. Also, rust can build up under the thin pad guide-shims causing the pads to stick in the brackets.
    Another thing to check is sometimes the old rubber brake hoses may look OK outside, but swell-up/plug-up inside, restricting release of brake fluid pressure after the brake pedal is released.
    wilcam47 and FirstTimeFirstGen like this.
  17. Aug 19, 2017 at 12:24 PM
    #57
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Hahaha that's some good stuff. Glad you got it taken care of. Enjoy your new clutch ;)
  18. Aug 30, 2017 at 8:42 PM
    #58
    Oz123456789
    Ozzzzz
    1995 Tacoma
  19. Aug 30, 2017 at 9:14 PM
    #59
    Mark D.
    My '96 Tacoma owner's manual calls for GL4 OR GL5 75w90 in the manual transmission. The oil I used was CarQuest GL5 75w90 MT-1 synthetic gear oil.
    Does the Mobil-1 have MT-1 printed somewhere on the jug?
    Some car manufacturers allow only GL4 oil. You might want to google or eMail Mobil and see what they say.
  20. Dec 5, 2017 at 7:02 PM
    #60
    Oz123456789
    Ozzzzz
    1995 Tacoma
    Hi everyone, I about to do my time belt and I want to change the seals..how many seals do I need? I think they are the camshaft seals, are there 2 or 3? Are they the same and where can I get them from? I order a time belt kit but they didn't come with them. I know I don't need to change them if they aren't bad but better to do them while they are out then later when they fail
