Transmission leak? Pics*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JasonJump, Sep 22, 2011.
  1. Sep 22, 2011 at 11:24 AM
    JasonJump
    JasonJump [OP] Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    So general consensus, should I switch to a high mileage 5-20 oil, and put an additive in to seal up? Or would that be bad if it had nothing to do with the engine? Thanks for all the help
  2. Sep 22, 2011 at 11:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, that.
    I see you did.
  3. Sep 22, 2011 at 11:37 AM
    JasonJump
    Yukon Oklahoma
    Yeah pretty easy fill
  4. Sep 22, 2011 at 11:51 AM
    JasonJump
    Yukon Oklahoma
    Bump
  5. Sep 22, 2011 at 11:53 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    have you determined what is leaking? Where are you low?
  6. Sep 22, 2011 at 11:56 AM
    JasonJump
    Yukon Oklahoma
    Can't check level of tranny without a dipstick, and not low on engine oil, but its also not a bad leak. Just want to prevent it from getting worse...
  7. Sep 22, 2011 at 12:08 PM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    looks more like some small seeping vs a leak - does fluid actually build up below it on the ground when you park?
    Most likely the rear main - i would monitor until the leaking gets more severe than whats pictured unless you like pulling t-cases and transmissions.
  8. Sep 22, 2011 at 12:14 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    you must be a former jeep owner like myself lol they all leaked. id leave it alone unless it gets really bad and is making puddles on the driveway
  9. Sep 22, 2011 at 12:15 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Just means it's a really small leak, not worth calling one but worth keeping an eye on during maintenance. Something that small in an engine with as many miles makes it a lot less likely to be a torn or damaged seal; it's just not as pliable as new.
    You aren't throwing it under the bus or anything by using high-mileage oil! It's still got lots of life in it, the oil just helps seals 'seal'. I have 120K on my Maxima and I'm thinking the same thing... when I was groveling underneath I saw a similar weep from the tc area. But don't put an additive in, it's completely unecessary if you use a quality HM oil, whether petroleum or synthetic.
    Oh, and that post about a timing chain cover leak running around to the back sounds like something to check out since the picture angle doesn't let you rule it out.
  10. Sep 22, 2011 at 12:24 PM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Pic of a leaking timing chain cover- usually leaks behind power steering pump. I had mine fixed under powertrain warranty- no charge.
  11. Sep 22, 2011 at 12:34 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Crank and rear main seal are "designed" to last around 120K but their life depends on a person driving during that 120K miles. so one person can easily do 200K miles on those seals other person will have them fail at around 100K
    Those seals are in engine so driving more on lower gears will make them fail faster more highway driving on higher gear and over the life of engine there are much less RPMS so seals last longer. Then you need to factor the quality of oil used.
    Those seals are just pieces of rubber so at some point they will have to be replaced just like every O-ring, gasket and seal in the car.
  12. Sep 22, 2011 at 12:37 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    ^^^this is where i would start, not by worrying about what weight oil i'm running, if you can't, most shops wouldnt charge to check for an oil leak.
  13. Sep 22, 2011 at 12:55 PM
    JasonJump
    Yukon Oklahoma
    Thats all great information, I will get that checked out and also keep an eye on it since its not leaving drops in the garage. Thanks for all the advice guys
  14. Sep 22, 2011 at 1:12 PM
    saugus
    saugus Well-Known Member
    Take a white clean rag to the leak and see if you can wipe a wet part. Inspect if it is ps, oil or trans.
  15. Sep 22, 2011 at 1:29 PM
    #35
    Tacoma Mike
    Southern Maine
    you have 120k on this thing and your worried about that ???
    Keep your eye on it for now. That could be like that for another 120K.
    I wouldn't touch that right now.
  16. Sep 22, 2011 at 1:37 PM
    #36
    JasonJump
    Yukon Oklahoma
    Good Idea, will do
    Haha I know, but my truck is very clean engine wise, I know its not a huge deal just don't want it to turn into one. I hope it goes like that for another 120k!
  17. Sep 22, 2011 at 2:26 PM
    #37
    Tacoma Mike
    Southern Maine
    I can understand. I see some with 180K that have looked like that for years.
    Just check it once in a while and if you notice a BIG change then you know it's time. :)
  18. Sep 22, 2011 at 4:50 PM
    #38
    JasonJump
    Yukon Oklahoma
    Well that reassuring, thanks for the input bud
  19. Dec 29, 2011 at 8:02 PM
    #39
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    btw never put a additive to "stop a leak" that stuff is like putting sludge in your motor. Im a toyota tech that looks like a rear main. I know im late on the response
  20. Dec 29, 2011 at 11:27 PM
    #40
    Syncros
    Syncros Well-Known Member
    If I read right you said you drop/drained the trans fluid?
    if so, thats probably just where the trans/bell housing got fluid on it from doing that, dust/dirt from driving the truck will stick to that residual oil.
    I say clean it off and see if it comes back before you get worried about anything.
