Transmission Max Temp - Toyota Answers
Discussion in 'Towing' started by ttubb, May 29, 2013.
  1. May 29, 2013 at 4:32 PM
    ttubb
    ttubb [OP] Member
    Terry
    Tucson/Crested Butte
    Tacoma TRD Off Road 4WD
    I recently asked Toyota for the number that turns on the A/T High Temp light on my 2013 V-6 Tacoma with the tow package. I have a Scan Gauge and I have seen as high as 230 on the Trans Temp so I was curious. Here is the answer:
    Dear Terry Tubb,
    Thank you for your follow-up email.
    We apologize that the Owner's Manual does not include the temperature in which the automatic transmission oil light will illuminate in your 2013 Tacoma.
    If you are towing with your vehicle, the automatic transmission oil temperature light may illuminate at 302 degrees. If the light comes on, it indicates that the auto transmission fluid temperature is too high. If the light flashes, it indicates a malfunction in the auto transmission system.
    For further evaluation, information and assistance, we recommend you contact your local Toyota dealership.
    Regards,
    Kym Strong
    Toyota Customer Experience
    Now we know.
    can0nfan2379 likes this.
  2. Jun 1, 2013 at 3:23 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    300 plus sounds very high. The fluid should run around 165 normal driving. Towing up to 220. When you get above 220 you start shortening the life of the transmission fluid, some claim as much as by 50%.
    Personally I would add another cooler that was big enough to keep it under 200 even under heavy towing conditions.
    Here is an article you might want to look at. Even though this is not about a Toyota it does not change the facts about the fluid and the transmission.
    http://www.roscommonequipmentcenter.com/news_notes/nn15.pdf
    http://waynestransmissions.com/2010/07/20/the-secret-to-extended-automatic-transmission-life/
  3. Nov 11, 2013 at 2:04 PM
    AFTaco
    AFTaco Well-Known Member
    Doug
    Anchorage, Alaska
    TRD Off-road
    Thanks for the info! I'm driving froma Alaska and was curious on when the light turns on. I got up to 240 in 20 degree weather. 300 def sounds high. I pulled over when I'm driving over 200 to let the tranny rest. Thanks again
  4. Nov 11, 2013 at 2:12 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Holy crap..... 300!?
    That's not a warning light, that's a $5K lightbulb!
