transmission Mount Center Bolt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Roadeater, Jan 27, 2016.
  1. Jan 27, 2016 at 4:40 PM
    Roadeater
    Roadeater [OP] Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    I just replaced the Trany mount of my 2004 pre runner v6 189000 miles. My question is how tight should be the big center bolt ? Should it be a little loose so the Trany Mount rubber can have some play?
    Here are the pics of old and new mounts.
  2. May 30, 2016 at 9:12 PM
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
    I'm about to have my transmission mount done, what brand mount did you use? Do you happen to have a part number if you used OEM?
    Also what did you end up torquing that bolt too?
    Thanks!
  3. May 30, 2016 at 9:35 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    that bolt in the center has no torque specifications, it's a fail-safe. when the rubbers break, that bolt keeps the tranny from shifting away from the mount. it doesn't need to be tight. just needs to not come off.
    Roadeater [OP] and YotaGurlIAm like this.
  4. May 31, 2016 at 12:46 PM
    Roadeater
    Kennesaw, Ga
    BassAckwards likes this.
  5. May 31, 2016 at 4:52 PM
    YotaGurlIAm
    Madison
    Arizona
    Stuff n' Thangs
  6. May 31, 2016 at 5:36 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Why did you replace the old mount? Vibrations? Did the new mount make a big difference?
  7. May 31, 2016 at 8:33 PM
    Roadeater
    Kennesaw, Ga
    There was no problem with the taco. I had just bought the truck with 184000 miles and decided to replace a few parts like , transmission mount, rotors, brake pads, timing belt, water pump, plugs, wires, diferencial fluid, transmission fluid.
    I drive 120 miles a day so I better keep the taco in good shape.
    Next thing I'm going to do is replace ball joints and rods. I am not a mechanic, i just watch a lot of YouTube videos before doing some work in my truck. :D
