Transmission mount question
Discussion in '1st Gen. Tacomas (1995-2004)' started by buck351, Jun 3, 2012.
  1. Jun 3, 2012 at 8:30 AM
    buck351
    buck351 [OP] Member
    So after searching high and low I haven't found an answer to this question. I have a 2002 S-Runner, manual trans and want to know the purpose is of the vertical bolt on the transmission mount. Tightening the bolt puts a compression load on the rubber in the mount. It looks like it's there for some sort of preload on the rubber. Anyone know?
  2. Jun 3, 2012 at 8:41 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Maybe the bolt is only threaded so far and you can only tighten it till there are no more threads.
  3. Jun 5, 2012 at 5:10 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    Was a PreRunner, now it isn't
    its to keep your trans in place if there is a catastrophic mount failure or if you are in an accident.
  4. Feb 18, 2013 at 8:28 PM
    00YotaComa
    00YotaComa HAWAII SELLS MORE TACOMAS THAN ANY OTHER STATE!
    Jack
    Big Island, Hawaii
    00 Tacoma SR5 TRD OFF ROAD
    1in. leveling kit, Deck plate mod, grey wire mod, K&N Filter , custom paint, Cyron LED lighting, head and tail blackouts
    If the rubber around that rear bolt is torn and bolt can be turned and wiggled around, would that be a cause of what i think is a driveline viberation (even if the two rubber blocks appear to be intact)? I have already changed the center bearing, all u joints and had drive shaft balanced.
  5. Feb 21, 2013 at 4:31 PM
    hossmaster
    League City, Tx
    maybe??? but that bolt is supposed to be "free" as it isnt doing anything until the oh shit moment.
  6. Feb 23, 2013 at 1:22 PM
    00YotaComa
    Jack
    Big Island, Hawaii
    Ok. Thanks! Kinda thought that. Guess I'll have to look elsewhere for problem. Ever heard of the front (4wd) driveshaft free spining at or around 50 mph in 2wd and maybe that is vibrating due to u-joints needing replaced? Gunna check to see any movement in that shaft today. :confused:
  7. Feb 23, 2013 at 9:52 PM
    Supertramp
    Supertramp dismember
    NC Mountains
    2002 Access cab TRD
    3 inch lift, Fox coilovers
    Not sure if front driveshaft turns in 2WD or not on Tacomas, but I had a TJ Jeep vibration (at around 50 mph) that drove me nuts until I figured out I had a bent front (4WD) driveshaft and replaced it.
    Maybe someone with more knowledge than me can answer whether or not it turns while in 2WD.
