Transmission pan gasket choice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Accipiter13, Dec 2, 2020.
  1. Dec 2, 2020 at 7:14 PM
    FirstGenTundra
    FirstGenTundra Well-Known Member
    Knoxville, TN
    2002 Tundra
    ICON suspension, SCS Ray 10's, Brute Force Fab bumper,
    I don't have a Tacoma but I do have a 02 Tundra with 173,000 miles. I recently had to replace my trans pan and while I was at it, I replaced the filter. In my opinion, this was a complete waste of time. First, the magnets were clean. There were zero metal shavings. Second, the filter was clean.
    I personally wouldn't waste time or money dropping the pan. If you do decide to do it, just get the Toyota FIPG.
    usmc2msu likes this.
  2. Dec 2, 2020 at 7:38 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Yup, I over torqued. Did realize it until 5 years later when I went to remove the drain plug again. No more torque wrenches for drain plugs for me.
    TnShooter[QUOTED] likes this.
  3. Dec 2, 2020 at 8:33 PM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    As @gearcruncher recommended I did the pan drop and replaced the strainer, clean the magnets and used the factory gasket. Tightened the pan bolts at about 4 ft/lbs and the drain bolt at 14-15 ft/lbs. :thumbsup:
  4. Dec 3, 2020 at 3:37 AM
    FirstGenTundra
    Knoxville, TN
    2002 Tundra
    That's true. Are you recommending he replace the solenoids when he drops the pan on his 5 speed?
  5. Dec 3, 2020 at 4:39 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    This is the kit I used, worked out well.
  6. Mar 6, 2021 at 9:58 AM
    Accipiter13
    Accipiter13 [OP] Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Well - I was another victim of the over-torqued drain plug from my previous fluid swap.
    My second fluid swap is on hold while I get a new pan/bolt delivered.
    At least I knew it was a possibility.
    spitdog likes this.
  7. Mar 6, 2021 at 4:37 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    There's enough material the trans pan drain can be tapped out to M12x1.25. Use a 27/64 drill. It's what I did with mine and it's not leaking.
    The stock trans drain plug is not designed for Toyotas' torque spec.
    Doc Samson likes this.
  8. Mar 6, 2021 at 4:45 PM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    When I stripped mine, it was only the bolt threads that stripped. Tapped the pan hole, bought a replacement bolt and it's been all good!
  9. Mar 6, 2021 at 5:10 PM
    dtaco10
    Dave
    I thought about doing this but, elected to go the way I did because I thought there would be less of a chance of stripping it in the future and if I ever sell it, the new owner shouldn't have to worry about it. An M12x1.25 can hold up to more torque than an M10x1.5. I'm sure I'll at least be doing drain and fills in the future. I've found from past experience that once a trans pan been dropped, the filter screen changed, and the pan cleaned out, there's little need to drop it again. Just do the drain and fill.
    Doc Samson[QUOTED] likes this.
  10. Mar 6, 2021 at 5:32 PM
    Doc Samson
    Almost NoVA
    None... yet.
    I actually had read what you did when it happened to me and thought I might have to go that route. Having never used a tap, I was a bit anxious but just took my time and it went well!
    In a sense, I'm glad it happened. My filter and magnets were well coated with fine metal goo, so a new filter and a magnet cleaning were definitely needed.
  11. Mar 9, 2021 at 5:03 PM
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    Does anyone have the torque specs on the filter?
  12. Mar 9, 2021 at 5:07 PM
    JAGCanada
    Canada
  13. Mar 9, 2021 at 5:17 PM
    Accipiter13
    California
    '11 DCLB 4x4 Sport
  14. Mar 13, 2021 at 2:16 PM
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    Thanks everyone. Finished the pan drop and filter change today along with the full fluid change. I did forget to put in the lubeguard platinum additive, but I figure 12+ quarts of new Maxlife should be ok.
    Stemmy, spitdog and Doc Samson like this.
