Transmission problem?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danbarone1994, Mar 14, 2016.
  1. Mar 14, 2016 at 7:34 PM
    danbarone1994
    danbarone1994 [OP] Well-Known Member
    Daniel
    2019 Toyota Tacoma Gray TRD OR V6 double cab
    LED headlights, TRD PRO grill, Spacer kit 2 in lift front
    When I back out of a parking spot and stop and shift into drive I have an issue sometimes the truck just acts like it's in neutral but if I shift into N and back into Drive it goes no problem. Anyone know? If there are any forums like this just please point me in the right direction.
  2. Mar 14, 2016 at 7:41 PM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    OP, if you have the tow package, it sounds like low tranny fluid. Since Toyota in their infinite wisdom decided to eliminate the trans dip stick there's threads here on how to check it.
    Brie likes this.
  3. Mar 14, 2016 at 8:04 PM
    danbarone1994
    Daniel
    Yes it was serviced just 5,000 miles ago with new filter and everything and fluid is full not low. That was my first thought was low fluid.
    Brie likes this.
  4. Mar 14, 2016 at 8:24 PM
    gearcruncher
    Canadain bumper technician
    Sounds like your shift cable is mis-aligned ?
    What transmission do you have ?
    4 speed automatic or 5 ?
    12TRDTacoma likes this.
  5. Mar 14, 2016 at 8:29 PM
    danbarone1994
    Daniel
    5 speed auto
  6. Mar 14, 2016 at 8:35 PM
    gearcruncher
    Its a computer controlled transmission . A computer scan would probably give you the best diagnostic .
    From your explanation I would check shift cable alignment to start .
    Some reading material here
    Some 2005 – 2009 model year Tacoma vehicles may exhibit a MIL “ON” condition with DTC P0705(Transmission Range Sensor Circuit Malfunction (PRNDL Input)) stored. Common symptoms withthis DTC can include possible delayed engagement into Reverse or Drive and possible harsh gearengagement when shifting between Park or Neutral into all other gears. Follow the procedure in thisTSB to determine if this service bulletin is applicable and to repair the vehicle.
    TSB - replacement of wiring loom for range sensor 2005 -2009
    http://www.scribd.com/doc/18857706/TSB027709
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
    http://bluegrasstoday.com/wp-content/uploads/2012/07/a750e_shudder.pdf
    Brie likes this.
  7. Mar 14, 2016 at 8:44 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  8. Mar 14, 2016 at 8:53 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Please explain.
  9. Mar 15, 2016 at 7:14 AM
    danbarone1994
    Daniel
    Yes that is the symptom I have but no mil light so still scan or just check the alignment first? I will report back with anything that I find.
    Brie likes this.
  10. Mar 15, 2016 at 8:37 AM
    gearcruncher
  11. Mar 15, 2016 at 8:44 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I want to point out that OP has 2005 pre-runner and those had problems with rear seal leaking transmission fluid. I am pretty sure there is even TSB for it.
  12. Mar 15, 2016 at 8:55 AM
    gearcruncher
    BlueT likes this.
  13. Mar 15, 2016 at 9:38 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    some people are claiming and speculating that if you have tow package you have additional
    tranny cooler and toyota forgot to add enough ATF to fill the cooler on some trucks [when they
    check and think the ATF is low...and a cooler is installed]
    some are claiming this...
    all I can say is I have tow package and a750f and nope, I have no tranny issues.
    I also don't care to check my fluid level because why ?
    it drives fine
    everything my tranny does is accountable for what input I have given the vehicle controls
  14. Mar 15, 2016 at 11:35 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think the low fluid issue is with the 2016s
    BlueT likes this.
  15. Mar 15, 2016 at 11:39 AM
    gearcruncher
  16. Mar 15, 2016 at 12:49 PM
    danbarone1994
    Daniel
    I had a problem with the leak and it is fixed and hasn't come back all fluid levels are good in the trans. I also had the drive shaft rebalanced and they modified the end at the axle so it would not make that issue come back. They said it was a very common issue on my generation and newer because the driveshaft design from Toyota.
  17. Mar 15, 2016 at 8:48 PM
    Lester Lugnut
    That's where I stand as well. Have a '15 PreRunner - no shifting issues or any of the symptoms of low fluid.
  18. Mar 16, 2016 at 9:24 AM
    danbarone1994
    Daniel
    Is this an issue that is leading to a rebuild being needed?
  19. Mar 22, 2016 at 5:30 AM
    gearcruncher
    I doubt he needs a rebuild , but a proper diagnostic should be performed
  20. Jun 15, 2016 at 2:16 PM
    danbarone1994
    Daniel
    I now work at a dealer but the shop foreman is not really that helpful.. he says get rid of the truck. I checked the fluid level with the scan tool factory. It is full.
    Sorry for such a late response.
