Transmission problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by ngarafalo, Nov 10, 2009.
  1. Nov 10, 2009 at 1:31 PM
    ngarafalo
    ngarafalo [OP] Well-Known Member
    Upstate, NY
    toytec ultimate lift k&n CAI tinted windows and tails weather tech digital floor mats
    I just had my tranny oil changed and before I took it in it was shifting fine and smooth. I got it back with new trans fluid and now it grind when shifting and makes weird noises when in nuetral. Any ideas what caused this. I had it done by an off the clock toyota dealer worker . Also the emergency brake was tightened bc it wasnt working. Please give me ideals of what could of went wrong because now it is grinding and I had it up for sale thinking the fluid change would do good not harm.
    By the way its a 2000 3.4L V6 4x4 taco Manuals trans
  2. Nov 10, 2009 at 1:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They may have used the wrong fluid. Im guessing its an Manual tranny?
  3. Nov 10, 2009 at 1:42 PM
    ngarafalo
    Upstate, NY
    Yeah it is a maual trans...and used synthetic like always...
  4. Nov 10, 2009 at 1:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Take it back to the shop, And let them know....Sounds like they may not have put enough in.....
  5. Nov 10, 2009 at 1:48 PM
    ngarafalo
    Upstate, NY
    Just got back from shop and they check the fluid level.. it was fine. Just pisses me off it was fine before I had the fluid changed
  6. Nov 10, 2009 at 1:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Did you tell them that?
  7. Nov 10, 2009 at 1:57 PM
    ngarafalo
    Upstate, NY
    Yeah but the problem is the guy did it off the clock. hes a toyo mechanic but as far as having it repaired by the dealer im SOL
  8. Nov 10, 2009 at 2:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well.....Do you know what fluid he used
