Transmission question
Discussion in '1st Gen. Tacomas (1995-2004)' started by slickyd, Jun 30, 2012.
  1. Jun 30, 2012 at 12:39 PM
    slickyd
    slickyd [OP] Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    I have searched and I cant find anything that sounds like what is happening to mine. I'll be driving down the road and it will sort of feel like the engine revs without the truck speeding up. And sometimes leaving from a stop it revs and slowly rolls or does nothing. It doesnt lasy long when it revs maybe a second or two just enough to notice it. My truck is a 2003 prerunner v6 auto with about 175,xxx on it. I dont really know that much about transmissions so I need some help as to what it might be and how much it might cost to fix.
  2. Jun 30, 2012 at 1:15 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Sounds like to me the clutch plates are slipping... Usually never a good thing. I'm not sure if transmission additive for worn clutch plates will help, but I'd continue to drive it till it dies.
  3. Jun 30, 2012 at 1:23 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Check the FLUID-!!!!!!!!!!
    From my experience--never put in an additive. Have it the fluid changed if it is at the correct level.
    If it smells "burnt" -you may have a problem--if its red it should not be too bad.
    Burnt automatic tranny fluid is BROWNISH.
    First--check the level.
    If its MILKY--water has gotten in. change it.
  4. Jun 30, 2012 at 1:25 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Is there a "throttle position sensor". If so, reset it.
  5. Jun 30, 2012 at 1:30 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    here are two links
  6. Jun 30, 2012 at 1:32 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    did not see a position sensor in the manual---FLUID LEVEL--FIRST.
  7. Jun 30, 2012 at 1:38 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Ok looks like im going to need to change the fluid. Its right below the low notch and I think its starting to turn brown. Im a little color blind so its hard to tell. Anything else I should know?
  8. Jun 30, 2012 at 1:41 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    I tried the links but its saying it can't be found
  9. Jun 30, 2012 at 1:49 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Here is the link for all trucks--find yours
    I use the online version.
    If the fliud is LOW--that could have the symptoms you are discribing. With 175K miles--IT IS TIME TO CHANGE IT.
  10. Jun 30, 2012 at 2:10 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    If it was my truck--change the fluid or have someone do it for you.
    You can see if the sympoms go away if you get the fluid to the proper level.
    I am not familiar toyota w/auto trannys. Other trucks have "adjustments" and "filters" that need to be changed periodically.
    Ever changed the fluid?-175K miles--past due!
    Keep me posted--
  11. Jun 30, 2012 at 7:27 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Im going to try and change the fluid tomorrow if the heat isnt to bad. Thank you for your help.
  12. Jun 30, 2012 at 7:34 PM
    Supra TT
    Eric
    Indiana
    Did you check your fluid when your truck was running?
  13. Jul 1, 2012 at 7:49 AM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Yes I did check it with it running
